http://bbs.espressif.com/viewtopic.php?p=3756#p3756
Resolved Issues(Bugs below are eligible for Bug Bounty Program):
- Espconn may fail to download big chunk of data (FOTA).
- Invalid TCP data sent issue.
- Fatal exceptions occur when change WiFi mode in WiFi scan callback.
- WiFi compatibility problem of special network card.
- Deep sleep may appear high current under certain circumstances.
- Add a new method to check memory leaks (API : system_show_malloc).
- Add print information when exception happens.
- Resolve the problem of os_timer_disarm.
- Optimize DHCP server, add API to set up the lease time of DHCP server. More details are in the “Added APIs”.
- Add event “EVENT_STAMODE_DHCP_TIMEOUT” for the DHCP timeout handling mechanism.
- Optimize handling of the reception of data and ZWP message.
- Add new APIs to support SSL bidirectional authentication. More details are in the “Added APIs”.
- Add new APIs to set up SSL certificates and encryption keys. espconn_secure_set_default_certificate & espconn_secure_set_default_private_key should be called to set SSL certificate and secure key, if ESP8266 runs as SSL server. More details are in the “Added APIs”.
- Optimize the process of FOTA (firmware upgrade through Wi-Fi).
- Optimize mDNS, and resolve the problem that in certain case the ESP8266 softAP can not work in the sta+AP mode.
- Release mesh as a lib in the esp_iot_sdk, and do not provide SDK of the mesh version any more.
- Optimize mesh’s handling of UDP packets.
- Optimize checking of the validity of the mesh API’s parameters.
- Add an API to set up the largest hop of mesh. For detailed information, go to mesh instructions.
- Optimize the process of powering up and booting to shorten booting time by 20 ms.
- Optimize the function of automatic frequency offset calibration.
- Optimize the function of sniffer.
- Strengthen reliability of the checking of beacon timeout.
- Optimize Wi-Fi event mechanism, and add event “ EVENT_SOFTAPMODE_PROBEREQRECVED”, and reason for a failed connection.
- Optimize Wi-Fi callback function and strengthen reliability of the software.
- Add the function of data transferring between stations in the soft-AP mode.
- Update SmartConfig to the version of 2.5.1.
- Update esp_init_data_default.bin. Please use the newest esp_init_data_default.bin when burning.
- Modify the espconn pointer in the receive callback of UDP. Parameters remote_ip and remote_port in it are the remote IP and port set by espconn_create. If users want to obtain IP and ports of the current sender, please call espconn_get_connection_info to get relevant information.
- System API
system_show_malloc : for checking memory leak, to print the memory usage. - DHCP server lease time related APIs
wifi_softap_set_dhcps_lease_time:set ESP8266 softAP DHCP server lease time.
wifi_softap_get_dhcps_lease_time:check ESP8266 softAP DHCP server lease time.
wifi_softap_reset_dhcps_lease_time:reset ESP8266 softAP DHCP server lease time which is 120 minutes by default. - wifi_station_dhcpc_set_maxtry:set the maximum number that ESP8266 station DHCP client will try to reconnect to the AP.
- Force sleep APIs
wifi_fpm_open:enable force sleep function.
wifi_fpm_close:disable force sleep function.
wifi_fpm_do_sleep:force ESP8266 enter sleep mode.
wifi_fpm_do_wakeup:wake ESP8266 up from force sleep.
wifi_fpm_set_sleep_type:set sleep type of force sleep function.
wifi_fpm_get_sleep_type:get sleep type of force sleep function. - Send packet freedom APIs (to send user-define 802.11 packets)
wifi_register_send_pkt_freedom_cb:register a callback for sending user-define 802.11 packets.
wifi_unregister_send_pkt_freedom_cb:unregister the callback for sending user-define 802.11 packets.
wifi_send_pkt_freedom:send user-define 802.11 packet. - RFID LOCP APIs
wifi_rfid_locp_recv_open:enable RFID LOCP to receive WDS packets.
wifi_rfid_locp_recv_close:disable RFID LOCP.
wifi_register_rfid_locp_recv_cb:register a callback of receiving WDS packets.
wifi_unregister_rfid_locp_recv_cb:unregister the callback of receiving WDS packets. - Rate Control APIs
wifi_set_user_fixed_rate:set the fixed rate and mask of sending data from ESP8266
wifi_get_user_fixed_rate:check the fixed rate and mask of ESP8266
wifi_set_user_sup_rate:set the rate range supported by ESP8266 to limit the rate of sending packets from other devices.
wifi_set_user_rate_limit:limit the rate of sending data from ESP8266.
wifi_set_user_limit_rate_mask:set the interfaces of ESP8266 whose rate of sending packets is limited by wifi_set_user_rate_limit.
wifi_get_user_limit_rate_mask:get the interfaces of ESP8266 whose rate of sending packets is limited by wifi_set_user_rate_limit. - Espconn APIs
espconn_sendto:send UDP data.
espconn_secure_cert_req_enable:enable certificates verification function when ESP8266 runs as SSL client.
espconn_secure_cert_req_disable:disable certificates verification function when ESP8266 runs as SSL client.
espconn_secure_set_default_certificate:set the certificate when ESP8266 runs as SSL server.
espconn_secure_set_default_private_key:set the encryption key when ESP8266 runs as SSL server. - SmartConfig API
smartconfig_set_type: set the protocol type of SmartConfig.
