OTA Updates — ESP8266 Arduino Core 2.4.0 documentation
Note: Windows users should select “Add python.exe to Path” (see below – this option is not selected by default).
Попытался через её же порт переписать саму себя BasicOTA и вот опять засада ))
Archiving built core (caching) in: Z:\TEMP\arduino_cache_88312\core\core_esp8266_esp8266_generic_CpuFrequency_80,FlashFreq_40,FlashMode_dio,UploadSpeed_115200,FlashSize_512K64,ResetMethod_ck,Debug_Disabled,DebugLevel_None_____6ba63ead392024094f12b614887dc489.a
Linking everything together...
"C:\Users\alex_1\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -g -Wall -Wextra -Os -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static "-LC:\Users\alex_1\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lib" "-LC:\Users\alex_1\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/ld" "-Teagle.flash.512k64.ld" -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,register_chipv6_phy -o "Z:\TEMP\arduino_build_728562/BasicOTA.ino.elf" -Wl,--start-group "Z:\TEMP\arduino_build_728562\sketch\BasicOTA.ino.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ESP8266WiFi\ESP8266WiFi.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ESP8266WiFi\ESP8266WiFiAP.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ESP8266WiFi\ESP8266WiFiMulti.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ESP8266WiFi\ESP8266WiFiSTA.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ESP8266WiFi\ESP8266WiFiScan.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ESP8266WiFi\WiFiClient.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ESP8266WiFi\WiFiClientSecure.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ESP8266WiFi\WiFiServer.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ESP8266WiFi\WiFiUdp.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ESP8266mDNS\ESP8266mDNS.cpp.o" "Z:\TEMP\arduino_build_728562\libraries\ArduinoOTA\ArduinoOTA.cpp.o" "Z:\TEMP\arduino_build_728562/arduino.ar" -lm -lgcc -lhal -lphy -lpp -lnet80211 -lwpa -lcrypto -lmain -lwps -laxtls -lsmartconfig -lmesh -lwpa2 -llwip_gcc -lstdc++ -Wl,--end-group "-LZ:\TEMP\arduino_build_728562"
"C:\Users\alex_1\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9/esptool.exe" -eo "C:\Users\alex_1\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/bootloaders/eboot/eboot.elf" -bo "Z:\TEMP\arduino_build_728562/BasicOTA.ino.bin" -bm dio -bf 40 -bz 512K -bs .text -bp 4096 -ec -eo "Z:\TEMP\arduino_build_728562/BasicOTA.ino.elf" -bs .irom0.text -bs .text -bs .data -bs .rodata -bc -ec
Используем библиотеку ESP8266WiFi версии 1.0 из папки: C:\Users\alex_1\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
Используем библиотеку ESP8266mDNS в папке: C:\Users\alex_1\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266mDNS (legacy)
Используем библиотеку ArduinoOTA версии 1.0 из папки: C:\Users\alex_1\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ArduinoOTA
Скетч использует 243663 байт (56%) памяти устройства. Всего доступно 434160 байт.
Глобальные переменные используют 33132 байт (40%) динамической памяти, оставляя 48788 байт для локальных переменных. Максимум: 81920 байт.
python.exe C:\Users\alex_1\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/espota.py -i 192.168.1.75 -p 8266 --auth= -f Z:\TEMP\arduino_build_728562/BasicOTA.ino.bin
12:22:41 [ERROR]: No response from device
Я надеюсь кнопки ресет и гпо15 нажимать же не надо если по воздуху, иначе если девайс запечатан в коробке под потолком, то какой от этих манипуляций тогда толк, но пусть я ошибаюсь
