энкодер freeRTOS
igorlab
Доброго врнмени суток! Господа, можно ли данную библиотеку работы с энкодером запихнуть в таски freeRTOS? отдельный таск выполняет то что в rotary_loop(); и значения encoderValue отправляются в очередь откуда читаются другим таском для обработки, получится ли или идея не очень?
#include "AiEsp32RotaryEncoder.h"
#include "Arduino.h"
connecting Rotary encoder
CLK (A pin) - to any microcontroler intput pin with interrupt -> in this example pin 32
DT (B pin) - to any microcontroler intput pin with interrupt -> in this example pin 21
SW (button pin) - to any microcontroler intput pin -> in this example pin 25
VCC - to microcontroler VCC (then set ROTARY_ENCODER_VCC_PIN -1) or in this example pin 25
GND - to microcontroler GND
#define ROTARY_ENCODER_A_PIN 32
#define ROTARY_ENCODER_B_PIN 21
#define ROTARY_ENCODER_BUTTON_PIN 25
#define ROTARY_ENCODER_VCC_PIN 27 /*put -1 of Rotary encoder Vcc is connected directly to 3,3V; else you can use declared output pin for powering rotary encoder */
AiEsp32RotaryEncoder rotaryEncoder = AiEsp32RotaryEncoder(ROTARY_ENCODER_A_PIN, ROTARY_ENCODER_B_PIN, ROTARY_ENCODER_BUTTON_PIN, ROTARY_ENCODER_VCC_PIN);
int test_limits = 2;
void rotary_onButtonClick() {
    //rotaryEncoder.reset();
    //rotaryEncoder.disable();
    rotaryEncoder.setBoundaries(-test_limits, test_limits, false);
    test_limits *= 2;
void rotary_loop() {
    //first lets handle rotary encoder button click
    if (rotaryEncoder.currentButtonState() == BUT_RELEASED) {
        //we can process it here or call separate function like:
        rotary_onButtonClick();
    //lets see if anything changed
    int16_t encoderDelta = rotaryEncoder.encoderChanged();
    //optionally we can ignore whenever there is no change
    if (encoderDelta == 0) return;
    //for some cases we only want to know if value is increased or decreased (typically for menu items)
    if (encoderDelta>0) Serial.print("+");
    if (encoderDelta<0) Serial.print("-");
    //for other cases we want to know what is current value. Additionally often we only want if something changed
    //example: when using rotary encoder to set termostat temperature, or sound volume etc
    //if value is changed compared to our last read
    if (encoderDelta!=0) {
        //now we need current value
        int16_t encoderValue = rotaryEncoder.readEncoder();
        //process new value. Here is simple output.
        Serial.print("Value: ");
        Serial.println(encoderValue);
    //we must initialize rorary encoder
    rotaryEncoder.begin();
    rotaryEncoder.setup([]{rotaryEncoder.readEncoder_ISR();});
    //optionally we can set boundaries and if values should cycle or not
    rotaryEncoder.setBoundaries(0, 10, true); //minValue, maxValue, cycle values (when max go to min and vice versa)
    //in loop call your custom function which will process rotary encoder values
    rotary_loop();
    delay(50);
    if (millis()>20000) rotaryEncoder.enable ();
можно.
А зачем?
у вас одно ядро.
Задачи будут исполняться последовательно.
можно сделать проще используя прерывание и все в одной задаче, а еще проще на основе NonOS.
igorlab
виноват, не указал что это для ESP32, уже есть часть кода на freertos, поэтому и спросил - не ясно надо использовать обычные функции или те что "FromISR"
