Denis Gricina
Пользователь Denis Gricina разместил новый ресурс:
ESP8089 - ESP8089_PREALLOC
Узнать больше об этом ресурсе...If you use a low-memory pad/tv-box or other machines which based on ESP8089,
you may need this program.
When some low-memory(normally less than 512MB) machine boot up, more android application
will run, so remain memory may be a lttle less, in this case, you may run this
program in the period when linux kernel boot. This program may pre-alloc enough
memory, then ESP8089 driver will get memory from ESP_PREALLOC rather than kernel
call such as kmalloc.
We suggest you use built-in of...
