#include "SPI.h"
#include "BlynkSimpleEsp8266.h"
#include "ESP8266WiFi.h"
#include "EEPROM.h"
#include "Adafruit_NeoPixel.h"
#define PIN D3
#define PIXELS_NUM 91
Adafruit_NeoPixel pxls = Adafruit_NeoPixel(PIXELS_NUM, PIN, NEO_GRB + NEO_KHZ800);
#define RAINBOW_MODE 1
#define RANDOM_COLORS_MODE 2
#define COLOR_WHEEL_MODE 3
#define STROBE_MODE 4
#define SLOW_MOTION_MODE 5
#define CUSTOM_MODE 6
#define RED_VAL 0
#define GREEN_VAL 1
#define BLUE_VAL 2
#define BRIGHTNESS_VAL 3
#define LED_EFFECT_VAL 4
#define BRIGHTNESS 127
#define R 255
#define G 255
#define B 255
#define LED_EFFECT_NUM CUSTOM_MODE
#define STROBE_COUNT 5
#define CHECKPOINT_EEPROM_BYTE 50
#define EEPROM_TIME_DELAY 1000
#define EEPROM_UPDATE_TIME 30000
#define FULL_EEPROM_ARRAY_SIZE 512
#define USER_VAL 1
#define BLYNK_PRINT Serial
byte DefaultSettings[] = {R, G, B, BRIGHTNESS, LED_EFFECT_NUM};
byte Settings[] = {0, 0, 0, 0, 0};
byte ColorWheelArr[30][3];
bool EepromUpdateFlag = true;
uint32_t EepromUpdateTimer;
uint32_t EepromSaveTimer = 0;
uint32_t LedEffectTimer;
uint8_t LedEffectNumber = 10;
uint8_t TemporaryEffectNumber;
uint16_t LedEffectTimeDelay = 25;
uint8_t j, k;
uint8_t HsvDegree = 0;
char auth[] = "********************************";
char ssid[] = "********************************";
char pass[] = "********************************";
bool PowerButtonState = false;
bool AnimationReverseFlag = false;
bool RandomColorsState = true;
pxls.begin();
randomSeed(analogRead(A0));
EEPROM.begin(FULL_EEPROM_ARRAY_SIZE);
if (EEPROM.read(CHECKPOINT_EEPROM_BYTE) == USER_VAL) {
for (int i = 0; i < (sizeof(Settings) / sizeof(Settings[0])); i++) {
byte EepromCurrentValue = EEPROM.read(i);
Settings[i] = EepromCurrentValue;
else {
Settings[i] = DefaultSettings[i];
TemporaryEffectNumber = Settings[LED_EFFECT_VAL];
for (int i = 0; i < PIXELS_NUM; i++) {
pxls.setPixelColor(i,
pxls.Color(0,
0,
0));
pxls.show();
Blynk.run();
if(Settings[LED_EFFECT_VAL] != CUSTOM_MODE && PowerButtonState){
if(Settings[LED_EFFECT_VAL] == RAINBOW_MODE){
if(millis() - LedEffectTimer > LedEffectTimeDelay){
LedEffectTimer = millis();
j++;
k=((uint16_t)(i*256 / PIXELS_NUM) + j);
if(k < 85) { Settings[RED_VAL]=k*3; Settings[GREEN_VAL]=255-Settings[RED_VAL]; Settings[BLUE_VAL]=0; } else
if(k < 170){ k -= 85; Settings[RED_VAL]=255-Settings[BLUE_VAL]; Settings[GREEN_VAL]=0; Settings[BLUE_VAL]=k*3; } else
{ k -= 170; Settings[RED_VAL]=0; Settings[GREEN_VAL]=k*3; Settings[BLUE_VAL]=255-Settings[GREEN_VAL]; }
pxls.Color(map(Settings[RED_VAL], 0, 255, 0, Settings[BRIGHTNESS_VAL]),
map(Settings[GREEN_VAL], 0, 255, 0, Settings[BRIGHTNESS_VAL]),
map(Settings[BLUE_VAL], 0, 255, 0, Settings[BRIGHTNESS_VAL])));
pxls.show();
else if(Settings[LED_EFFECT_VAL] == RANDOM_COLORS_MODE){
int8_t n = random(3);
if(n == 0){Settings[RED_VAL] = 0;} else {Settings[RED_VAL] = random(255);}
if(n == 1){Settings[GREEN_VAL] = 0;} else {Settings[GREEN_VAL] = random(255);}
if(n == 2){Settings[BLUE_VAL] = 0;} else {Settings[BLUE_VAL] = random(255);}
pxls.show();
else if(Settings[LED_EFFECT_VAL] == COLOR_WHEEL_MODE){
if(millis() - LedEffectTimer > LedEffectTimeDelay*2){
if(HsvDegree == 0 ){HsvDegree = 42; } else
if(HsvDegree == 42 ){HsvDegree = 85; } else
if(HsvDegree == 85 ){HsvDegree = 127;} else
if(HsvDegree == 127){HsvDegree = 170;} else
if(HsvDegree == 170){HsvDegree = 212;} else
if(HsvDegree == 212){HsvDegree = 0; }
if(HsvDegree < 85) {Settings[BLUE_VAL] = 0; Settings[RED_VAL] = HsvDegree*3; Settings[GREEN_VAL] = 255 - Settings[RED_VAL]; } else
if(HsvDegree < 170){Settings[GREEN_VAL] = 0; Settings[BLUE_VAL] = HsvDegree*3; Settings[RED_VAL] = 255 - Settings[BLUE_VAL]; } else
{Settings[RED_VAL] = 0; Settings[GREEN_VAL] = HsvDegree*3; Settings[BLUE_VAL] = 255 - Settings[GREEN_VAL];}
pxls.fill(pxls.Color(map(Settings[RED_VAL], 0, 255, 0, Settings[BRIGHTNESS_VAL]),
pxls.show();
else if(Settings[LED_EFFECT_VAL] == STROBE_MODE){
for(int j = 0; j < STROBE_COUNT; j++) {
pxls.fill(pxls.Color(map(R, 0, 255, 0, Settings[BRIGHTNESS_VAL]),
map(G, 0, 255, 0, Settings[BRIGHTNESS_VAL]),
map(B, 0, 255, 0, Settings[BRIGHTNESS_VAL])));
pxls.show();
delay(LedEffectTimeDelay / 2);
pxls.fill(0,0,0);
pxls.show();
else if(Settings[LED_EFFECT_VAL] == SLOW_MOTION_MODE){
if(RandomColorsState){
RandomColorsState = false;
int8_t RandomNumber = random(3);
if(RandomNumber == 0){ColorWheelArr[i][RED_VAL] = 0;} else {ColorWheelArr[i][RED_VAL] = random(255);}
if(RandomNumber == 1){ColorWheelArr[i][GREEN_VAL] = 0;} else {ColorWheelArr[i][GREEN_VAL] = random(255);}
if(RandomNumber == 2){ColorWheelArr[i][BLUE_VAL] = 0;} else {ColorWheelArr[i][BLUE_VAL] = random(255);}
if(!AnimationReverseFlag){
for(int j = 0; j <= Settings[BRIGHTNESS_VAL]; j++){
if (j == Settings[BRIGHTNESS_VAL]) {AnimationReverseFlag = true;}
pxls.Color(map(ColorWheelArr[i][RED_VAL], 0, 255, 0, j),
map(ColorWheelArr[i][GREEN_VAL], 0, 255, 0, j),
map(ColorWheelArr[i][BLUE_VAL], 0, 255, 0, j)));
pxls.show();
else {
for(int j = Settings[BRIGHTNESS_VAL]; j >= 0; j--){
if (j == 0) {AnimationReverseFlag = false; RandomColorsState = true;}
pxls.show();
