Nodemcu server
Serega4789
Добрый день! Сервер перестаёт работать если добавляю код с часами дисплеями и сервомоторм.
<html>\
<head>\
<meta http-equiv='refresh' Connection:'close' content='10'/>
Код автообновления как отправить через переменную s
Serega4789
#include <OneWire.h>
bool led1IsOn = false;
bool led2IsOn = false;
bool led3IsOn = false;
const int LED_0 = 16;
const int LED_1 = 5;
const int LED_2 = 2;
const int oneWireBus = 4;
const char* ssid = "";
const char* password = "";
float temperatureC = 0.0f;
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
OneWire oneWire(oneWireBus);
  pinMode(LED_0, OUTPUT);
  pinMode(LED_1, OUTPUT);
  pinMode(LED_2, OUTPUT);
  delay(1000);
  digitalWrite(LED_0, HIGH);
  digitalWrite(LED_1, HIGH);
  digitalWrite(LED_2, HIGH);
  delay(1000);
  digitalWrite(LED_0, LOW);
  digitalWrite(LED_1, LOW);
  digitalWrite(LED_2, LOW);
  delay(10);
  sensors.begin();
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
//Сюда вставляю код
  sensors.requestTemperatures();
  if (!client) {
    return;
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  Serial.println(req);
  // Match the request
  controller(req, client);
  client.flush();
  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n";
  s += temperatureC;
  // Send the response to the client
  client.print(s);
  delay(1);
  Serial.println("Client disonnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is detroyed
void controller(String req,  WiFiClient client){
   if (req.indexOf("/temperature") != -1){
     temperatureC = sensors.getTempCByIndex(0);
     Serial.println("Showing temperature");
    } else if(req.indexOf("/led1") != -1){
     setLedState(LED_0, led1IsOn);
     led1IsOn = !led1IsOn;
    } else if(req.indexOf("/led2") != -1){
      setLedState(LED_1, led2IsOn);
      led2IsOn = !led2IsOn;
    } else if(req.indexOf("/led3") != -1){
      setLedState(LED_2, led3IsOn);
      led3IsOn = !led3IsOn;
    } else {
    Serial.println("invalid request");
    client.stop();
    return;
void setLedState(int led, bool state){
  if(!state){
    digitalWrite(led, HIGH);
  } else {
    digitalWrite(led, LOW);}
На все нужно время, а если бездумно вставлять, в каждую итерацию цикла, sensors.requestTemperatures(); и подобное, его не напасешься.
sensors.requestTemperatures(); само не занимает много времени, но следующее считывание температуры будет с задержкой.
Serega4789
Этой функции нет в программе из архива только перечень переменных отправляемых с nodemcu каркас вайфай
Serega4789
Подскажите какую часть кода вайфай вызывать и с какой периодичностью чтобы добавить основной код с дисплеем и датчиками
Serega4789
Я хотел так сделать, создать функцию с кодом wifi и вызывать только тогда когда нужно что то отправить с сервера, но как быть если нужно ещё и принять например нажатие кнопки в приложении?
Начните с алгоритма, можно на бумажке, узнаете какие команды надо выполнять за один проход цикла и сколько надо на это времени.
Чаще всего пытаются выполнить сто команд за проход, вместо скажем одной команды за один проход цикла.
Serega4789
Хорошо, если знакомы с flprog могу скинуть файл там поблочно расписано а модуль с кодом вайфай в последней плате. Этот код с годовностью клиента должен постоянно крутиться как я понял или вызываться только когда нужен?
