ESP8266 SDK(esp_iot_sdk_v1.2.0_15_07_03)
esp_iot_sdk_v1.2.0_15_07_03 Release Note
Resolved Issues(Bugs below are eligible for Bug Bounty Program):
1.TLS server disconnect to ESP8266 may cause crash. [孙新虎]
Optimization:
1.Update SmartConfig to version 2.4 , corresponding to ESPTOUCH APP v0.3.4 (https://github.com/EspressifApp/), delete parameter "sc_type type" in smartconfig_start, SmartConfig type can be got automatically.
2.Add parameter "sint16 freq_offset; " in structure "bss_info" to get AP's frequency offset.
3.Folder "ld" is updated, please use the latest one (\esp_iot_sdk_v1.2.0\ld )
4.Add UDP transparent transmission example in documentation "4B-ESP8266__AT Command Examples"
5.Revise the scan issue that may cause Wi-Fi connection break.
6.Add ESP-NOW function, more details in "Add APIs"
7.Add WPS function,more details in "Add APIs"
8.Fixed a DNS fail issue with special router
9.Optimize espconn,revise issues below:
(1) enter sent callback late in UDP transmission
(2) TCP shakehand may fail issue
(3) SSL connection fail may cause crash
(4) optimize SSL error handler
10. Memory optimization
Add APIs:
1.ESP-NOW APIs
esp_now_init: init ESP-NOW function
esp_now_deinit: deinit ESP-NOW function
esp_now_register_recv_cb: register ESP-NOW receive callback
esp_now_unregister_recv_cb: unregister ESP-NOW receive callback
esp_now_send: send ESP-NOW packet
esp_now_add_peer: add an ESP-NOW peer
esp_now_del_peer: delete an ESP-NOW peer
esp_now_set_self_role: set ESP-NOW role of device itself
esp_now_get_self_role: get ESP-NOW role of device itself
esp_now_set_peer_role: set ESP-NOW role about another device
esp_now_get_peer_role: get ESP-NOW role about another device
esp_now_set_peer_key: set ESP-NOW key of a device
esp_now_get_peer_key: get ESP-NOW key of a device
2. WPS APIs
wifi_wps_enable : enable WPS function
wifi_wps_disable: disable WPS function
wifi_wps_start: start WPS communication
wifi_set_wps_cb: set WPS callback
3.software watchdog APIs
system_soft_wdt_stop: stop software watchdog
system_soft_wdt_restart: restart software watchdog
4.sntp_get_timezone: get SNTP timezone
AT_v0.30 Release Note:
Note: For AT firmware to support FOTA, flash size need to be 1024KB or more than that.
1.Command "AT+CWSTARTSMART" need not parameter any more, SmartConfig type can be got automatically.
2.AP's frequency offset can be got by command "AT+CWLAP"
3.Memory optimization
Optimization:
Add APIs:
1.ESP-NOW APIs
2. WPS APIs
