Нужна помощь WebServer
TAHKICT
Написал сервер для мигания светодиодом.
#include <ESP8266WebServer.h>
#include <ESP8266HTTPClient.h>
const String nodeId = "4";
const char* ssid = "*";
const char* password = "*";
const String serverURL = "http://192.168.1.129:8181";
const String aliveRequestURL = "/core-rest-api/for-nodes/alive-request-from-node";
ESP8266WebServer server(80);   //Web server object. Will be listening in port 80 (default for HTTP)
  pinMode(1,OUTPUT);
  pinMode(2,OUTPUT);
  WiFi.begin(ssid, password); //Connect to the WiFi network
  while (WiFi.status() != WL_CONNECTED) { //Wait for connection
    delay(500);
    Serial.println("Waiting to connect…");
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP());  //Print the local IP to access the server
  sendAliveRequestToServer();
  server.on("/command-from-server", handleRequestFromServer); //Associate the handler function to the path
  server.begin();                                    //Start the server
  Serial.println("Server listening");
  server.handleClient();    //Handling of incoming requests
void handleRequestFromServer() {
  String message = "";
  if (server.arg("switch")== ""){     //Parameter not found
    message = "Switch argument not found.";
  } else {     //Parameter found
    if(powerSocketSwitch(server.arg("switch")) == true){
      message = "Switched successfully.";
    } else {
      message = "Switched unsuccessfully. Command is not correct.";
  server.send(200, "text/plain", message);    //Returns the HTTP response
boolean powerSocketSwitch(String command){
  if(command == "checked"){
    Serial.println("command checked");
    digitalWrite(1, HIGH);
    digitalWrite(2, HIGH);
    return true;
  } else if(command == "unchecked"){
    Serial.println("command unchecked");
    digitalWrite(1, LOW);
    digitalWrite(2, LOW);
    return true;
  return false;
void sendAliveRequestToServer() {
  if (WiFi.status() == WL_CONNECTED) { //Check WiFi connection status
    Serial.println("send Alive Request To Server: " + serverURL + aliveRequestURL + "?id=" + nodeId);
    HTTPClient http;  //Declare an object of class HTTPClient
    http.begin(serverURL + aliveRequestURL + "?id=" + nodeId);  //Specify request destination
    int httpCode = http.GET();                                  //Send the request
    if (httpCode > 0) { //Check the returning code
      String payload = http.getString();   //Get the request response payload
      Serial.println(payload);                     //Print the response payload
    http.end();   //Close connection
Возвращает ответ про то что все отработало нормально, но по факту светодиод не загорается.
P.S. Скетч, в котором я не разворачиваю сервер и просто мигаю диодом работает нормально.
Подскажите пожалуйста, что не так?
TAHKICT
Причину чего лед не мигал нашел. Оказалось был конфликт с Serial.begin.
Рабочий скетч:
  pinMode(1,OUTPUT);
    delay(500);
    } else {
    return true;
  } else if(command == "checked"){
    return true;
  return false;
Хочу обратить на участок кода, который работает ровно наоборот, чем я задумывал
    return true;
    return true;
  return false;
Команда "checked" у меня приходит когда диод должен включиться, а получалось наоборот. Поэтому я поменял местами. Но хотелось бы узнать почему так. Кто-нибудь в курсе?
tretyakov_sa
Если вы о встроенном диоде то он загорается когда на выходи LOW и гаснет когда на выходе HIGH.
