Simple WEB version: 0.1.0
SDK version: 0.9.5
Flash Header:
Number of segments: 3
SPI Flash Interface: QIO
SPI CLK: 40MHz
Flash size: 512K
Entry point: 0x40100004
Segment 1: offset: 0x40100000, size: 26028
Segment 2: offset: 0x3ffe8000, size: 2744
Segment 3: offset: 0x3ffe8ac0, size: 4400
Real Flash size: 524288 bytes
Found free IRAM: base:0x401065ac, size:6740 bytes
System memory:
data : 0x3ffe8000 ~ 0x3ffe8ab8, len: 2744
rodata: 0x3ffe8ac0 ~ 0x3ffe9bf0, len: 4400
bss : 0x3ffe9bf0 ~ 0x3fff1a80, len: 32400
heap : 0x3fff1a80 ~ 0x3fffc000, len: 42368
Current 'heap' size: 42096 bytes
Set CPU CLK: 160 MHz
WiFi mode:3 chl:1 phy:3 dhcp:1/1
AP:ESP8266[7] hiden(0) psw:0123456789 au:0 chl:1 maxcon:4 beacon:100
ip:192.168.4.1 gw:192.168.4.1 msk:255.255.255.0 mac:1a:fe:34:98:d5:84
DHCP ip:192.168.4.2..192.168.4.6
ST:HOMEAP psw:0123456789 b:0 ff:ff:ff:ff:ff:ff ac:0
ip:0.0.0.0 gw:0.0.0.0 msk:0.0.0.0 mac:18:fe:34:98:d5:84
sleep:0
sleep disable
Disk init: 33 files, addr = 0x0001e000
TCP Server init on port 80 - Ok
Max connection 99, time waits 5 & 5, min heap size 14528
TCP Server start - Ok
TCP Server init on port 12345 - Ok
Max connection 1, time waits 0 & 0, min heap size 14528
mode : sta(18:fe:34:98:d5:84) + softAP(1a:fe:34:98:d5:84)
add if0
dhcp server start
ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)
add if1
pm close 0 0 0/418391
bcn 100
Test rtc memory retention... changes, new write
