Обсуждение ASUS Tinker Board - еще одна альтернатива Raspberry Pi 3
Asus Tinker Board specifications:
  • SoC – Rockchip 3288 quad core ARM Cortex A17 up to 1.8 GHz with Mali-T764 GPU supporting OpenGL ES 1.1/2.0 /3.0, and OpenCL 1.1
  • System Memory – 2GB LPDDR3, dual channel
  • Storage – 8 or 32 GB eMMC flash + micro SD slot
  • Video output & Display I/F
    • 1x HDMI 2.0 up to 3840×2160@60p
    • 1x 15-pin MIPI DSI supporting HD resolution
  • Audio – 1x 3.5mm audio jack; Realtek HD codec with 192KHz/24-bit audio
  • Connectivity – Gigabit Ethernet, 802.11 b/g/n WiFi, Bluetooth 4.0 + EDR
  • USB – 4x USB 2.0 host ports, 1x micro USB port (for power)
  • Expansion Headers
    • 40-pin “somewhat Raspberry Pi compatible” header with up to 28x GPIOs, 2x SPI, 2x I2C, 4x UART, 2x PWM, 1x PCM/I2S, 5V, 3.3V, and GND
    • 2-pin contact point with 1x PWM signal, 1x S/PDIF signal
  • Misc – Button, unpopulated fan header
  • Power Supply – 5V/2A via micro USB port
  • Dimensions – 85.6 x 54 cm
