Делюсь опытом Датчик dht11 + управление нагрузкой
Alex_dv
#include <DHT.h>
#define DHTPIN            2         // Pin which is connected to the DHT sensor.
// Uncomment the type of sensor in use:
#define DHTTYPE           DHT11     // DHT 11
//#define DHTTYPE           DHT22     // DHT 22 (AM2302)
//#define DHTTYPE           DHT21     // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
const char* ssid = "YourSSID"; //
const char* password = "xxxxxxxxxx"; //paste your password here
int ledPin = 1; // GPIO1
WiFiServer server(80);
  delay(5000);
  dht.begin();
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
  Serial.print("Use this URL to connect: ");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
  int timeout;
  if (!client) {
    return;
  Serial.println("new client");
  while(!client.available()){
    delay(1);
    timeout++;
    if(timeout>10000) {break;}
  timeout=0;
  String request = client.readStringUntil('\r');
  Serial.println(request);
  client.flush();
  // Match the request
  int value = LOW;
  if (request.indexOf("/LED=ON") != -1)  {
    value = LOW;
  if (request.indexOf("/LED=OFF") != -1)  {
    digitalWrite(ledPin, HIGH);
    value = HIGH;
// Set ledPin according to the request
//  digitalWrite(ledPin, value);
  // Return the response
  client.println("Content-Type: text/html");
  client.println(""); //  do not forget this one
  client.println("<!DOCTYPE HTML>");
  client.println("<html>");
  client.print("<strong>Hi! I'm ESP8266</strong>");
  client.print("<br><br>");
  client.print("My blue LED is now: ");
  if(value == LOW) {
    client.println("On");
  } else {
    client.println("Off");
  client.println("<br><br>");
  client.println("Temperature: ");
  client.println(dht.readTemperature());
  client.println("C");
  client.println("Humidity: ");
  client.println(dht.readHumidity());
  client.println("%");
  client.println("<a href=\"/LED=ON\"\"><button>Turn On </button></a>");
  client.println("<a href=\"/LED=OFF\"\"><button>Turn Off </button></a><br />");
  client.println("</html>");
  delay(1);
  Serial.println("Client disonnected");
  Serial.println("");
Всем привет, сделал первый прототип на esp8266, может кому понадобиться: само устройство состоит из двух блоков, esp 01 с резисторным делителем напряжения на входе RX и источника питания на базе lm1117 3.3 v . Питается схема от эппловского блока питания 5в 1а (но скорее всего он даёт не более 500 ма).
Программа считывает данные с датчика с использованием adafruit’овской библиотеки dht и передаёт их на веб страницу. Фото устройства и страницы прилагаю.
P.S. esp НЕ хватает силы тока встроенного источника питания от usb uart конвертеров! Используйте внешний источник питания с током от 500 мА и соединяете землю источника и конвертера при прошивке чипа.
Alex_dv
и еще, конвертер на базе ft232 стабильно не работает через переходник usb type c -> usb 3.0, а через порт usb 2.0 работает нормально
