Подскажите как получить данные из топика и разложить их в переменные float которые должны соответствовать своим топикам, я не понимаю как это сделать когда все валит в одно место.
* Simple example to demo the esp-link MQTT client
#include <ELClient.h>
#include <ELClientCmd.h>
#include <ELClientMqtt.h>
// Initialize a connection to esp-link using the normal hardware serial port both for
// SLIP and for debug messages.
ELClient esp(&Serial, &Serial);
// Initialize CMD client (for GetTime)
ELClientCmd cmd(&esp);
// Initialize the MQTT client
ELClientMqtt mqtt(&esp);
// Callback made from esp-link to notify of wifi status changes
// Here we just print something out for grins
void wifiCb(void* response) {
ELClientResponse *res = (ELClientResponse*)response;
if (res->argc() == 1) {
uint8_t status;
res->popArg(&status, 1);
if(status == STATION_GOT_IP) {
Serial.println("WIFI CONNECTED");
} else {
Serial.print("WIFI NOT READY: ");
Serial.println(status);
bool connected;
// Callback when MQTT is connected
void mqttConnected(void* response) {
Serial.println("MQTT connected!");
mqtt.subscribe("/esp-link/1");
mqtt.subscribe("/hello/world/#");
//mqtt.subscribe("/esp-link/2", 1);
//mqtt.publish("/esp-link/0", "test1");
connected = true;
// Callback when MQTT is disconnected
void mqttDisconnected(void* response) {
Serial.println("MQTT disconnected");
connected = false;
// Callback when an MQTT message arrives for one of our subscriptions
void mqttData(void* response) {
ELClientResponse *res = (ELClientResponse *)response;
Serial.print("Received: topic=");
String topic = res->popString();
Serial.println(topic);
Serial.print("data=");
String data = res->popString(); // <= валит все сюда
Serial.println(data);
void mqttPublished(void* response) {
Serial.println("MQTT published");
Serial.println("EL-Client starting!");
// Sync-up with esp-link, this is required at the start of any sketch and initializes the
// callbacks to the wifi status change callback. The callback gets called with the initial
// status right after Sync() below completes.
esp.wifiCb.attach(wifiCb); // wifi status change callback, optional (delete if not desired)
bool ok;
do {
ok = esp.Sync(); // sync up with esp-link, blocks for up to 2 seconds
if (!ok) Serial.println("EL-Client sync failed!");
} while(!ok);
Serial.println("EL-Client synced!");
// Set-up callbacks for events and initialize with es-link.
mqtt.connectedCb.attach(mqttConnected);
mqtt.disconnectedCb.attach(mqttDisconnected);
mqtt.publishedCb.attach(mqttPublished);
mqtt.dataCb.attach(mqttData);
mqtt.setup();
//Serial.println("ARDUINO: setup mqtt lwt");
//mqtt.lwt("/lwt", "offline", 0, 0); //or mqtt.lwt("/lwt", "offline");
Serial.println("EL-MQTT ready");
static int count;
static uint32_t last;
esp.Process();
if (connected && (millis()-last) > 4000) {
Serial.println("publishing");
char buf[12];
itoa(count++, buf, 10);
mqtt.publish("/esp-link/1", buf);
itoa(count+99, buf, 10);
mqtt.publish("/hello/world/arduino", buf);
uint32_t t = cmd.GetTime();
Serial.print("Time: "); Serial.println(t);
last = millis();
