maxs2389081
Шью через ArduinoIDE
Esp была подключена правильно, через usb-ttl , отдельное питание, gpio0 при прошивке на землю, перезапускаю замыканием reset на землю перед каждой прошивкой.
Раньше всё работало.
Пишет:
Пишет:
esptool v0.4.13 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 115200
setting port from COM1 to COM8
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
espcomm_send_command: receiving 36 bytes of data
warning: espcomm_send_command: wrong direction/command: 0x00 0x08, expected 0x01 0x08
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
Произошла ошибка при загрузке скетча
resetting board
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
resetting board
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
warning: espcomm_sync failed
error: espcomm_open failed
espcomm_upload_file
espcomm_upload_mem
opening bootloader
resetting board
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
resetting board
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
resetting board
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
trying to connect
flush start
flush complete
