Hello!
I'm using ESP8266 with actual firmware ESP8266_NONOS_SDK_V2.0.0_16_08_10.
I do database query to PHP + MySQL using at commands.
On Internet network
... ESP8266 works fine for example: http://zzzzzzz.zzzzzzzzz.zz/dodaj_rek.php?n=129&u=1488723073&d=-51&s=203
AT+CWMODE_CUR=3
AT+CIPSTART="TCP","zzzzzzz.zzzzzzzzz.zz",80
AT+CIPSEND=89
GET dodaj_rek.php?n=129&u=1488723073&d=-51&s=203 HTTP/1.1\r\nHost: zzzzzzz.zzzzzzzzz.zz\r\n\r\n
server answer:
+IPD,189:HTTP/1.1 200 OK
Date: Mon, 06 Mar 2017 02:29:39 GMT
Server: Apache/2
X-Powered-By: PHP/5.3.29
Vary: User-Agent
Content-Length: 11
Content-Type: text/html; charset=UTF-8
CLOSED
and new record in database has been added correctly.
Server in local network
I installed actual version of Apache, PHP and MySQL on computer with Win10 and IP 192.168.1.51 listenning on port 80.
SSL is not enabled.
When I'm using such url:
192.168.1.51/dodaj_rek.php?n=129&u=1488723073&d=-51&s=203
in web browser of any machine (computer, smartfon, tablet) in my local network via WiFi or LAN, every thing works fine.
Problem arises when i'm trying do the same using ESP8266.
AT+CWMODE_CUR=3
AT+CIPSTART="TCP","192.168.1.51",80
AT+CIPSEND=81
GET dodaj_rek.php?n=129&u=1488723073&d=-51&s=203 HTTP/1.1\r\nHost: 192.168.1.51\r\n\r\n
AT+CIPSTART responds correctly connecting to the server
AT+CIPOSEND responds correctly showing prompt: >
After sending GET responds correctly showing:
Recv 81 bytes
SEND OK
but generates error: 400 Bad Request
+IPD,418:HTTP/1.1 400 Bad Request
Date: Mon, 06 Mar 2017 02:40:29 GMT
Server: Apache/2.4.25 (Win64) PHP/5.6.30
Content-Length: 226
Connection: close
Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>400 Bad Request</title>
</head><body>
<h1>Bad Request</h1>
<p>Your browser sent a request that this server could not understand.<br /></p>
</body></html>
CLOSED
I attach configuration files of PHP and Apache.
I spent a lot of time and I can not find the reason
On Internet network
AT+CWMODE_CUR=3
AT+CIPSEND=89
server answer:
Server: Apache/2
Vary: User-Agent
Content-Length: 11
CLOSED
SSL is not enabled.
AT+CWMODE_CUR=3
AT+CIPSEND=81
Recv 81 bytes
SEND OK
Content-Length: 226
Connection: close
<html><head>
</head><body>
</body></html>
CLOSED
28.3 KB Просмотры: 0
