zakharovjs
ESPlorer вылетает при попытке подключиться к ком порту с esp8266. Смена бодрейта итд не помогает. Лог с ошибкой прилагается.
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000007110b5db, pid=14376, tid=6232
# JRE version: Java(TM) SE Runtime Environment (10.0.1+10) (build 10.0.1+10)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (10.0.1+10, mixed mode, tiered, compressed oops, g1 gc, windows-amd64)
# Problematic frame:
# C [jSSC-2.8_x86_64.dll+0xb5db]
# No core dump will be written. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# Crash Report
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- S U M M A R Y ------------
Command Line: C:\Users\zakha\Desktop\ESPlorer\ESPlorer.jar
Host: Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz, 4 cores, 7G, Windows 10 , 64 bit Build 16299 (10.0.16299.431)
Time: Wed May 23 11:48:29 2018 RTZ 8 (ceia) elapsed time: 7 seconds (0d 0h 0m 7s)
--------------- T H R E A D ---------------
Current thread (0x000002ce1807c800): JavaThread "AWT-EventQueue-0" [_thread_in_native, id=6232, stack(0x000000f1c2f00000,0x000000f1c3000000)]
Stack: [0x000000f1c2f00000,0x000000f1c3000000], sp=0x000000f1c2ffb130, free space=1004k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j jssc.SerialNativeInterface.openPort(Ljava/lang/String;Z)J+0
j jssc.SerialPort.openPort()Z+65
j ESPlorer.ESPlorer.portOpen()Z+108
j ESPlorer.ESPlorer.OpenActionPerformed(Ljava/awt/event/ActionEventV+160
j ESPlorer.ESPlorer.access$27300(LESPlorer/ESPlorer;Ljava/awt/event/ActionEventV+2
j ESPlorer.ESPlorer$271.actionPerformed(Ljava/awt/event/ActionEventV+5
j javax.swing.AbstractButton.fireActionPerformed(Ljava/awt/event/ActionEventV+84 java.desktop@10.0.1
j javax.swing.AbstractButton$Handler.actionPerformed(Ljava/awt/event/ActionEventV+5 java.desktop@10.0.1
j javax.swing.DefaultButtonModel.fireActionPerformed(Ljava/awt/event/ActionEventV+34 java.desktop@10.0.1
j javax.swing.JToggleButton$ToggleButtonModel.setPressed(Z)V+148 java.desktop@10.0.1
j javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Ljava/awt/event/MouseEventV+35 java.desktop@10.0.1
j java.awt.AWTEventMulticaster.mouseReleased(Ljava/awt/event/MouseEventV+8 java.desktop@10.0.1
j java.awt.Component.processMouseEvent(Ljava/awt/event/MouseEventV+64 java.desktop@10.0.1
j javax.swing.JComponent.processMouseEvent(Ljava/awt/event/MouseEventV+23 java.desktop@10.0.1
J 4254 c1 java.awt.Component.processEvent(Ljava/awt/AWTEventV java.desktop@10.0.1 (220 bytes) @ 0x000002ce084c729c [0x000002ce084c6d80+0x000000000000051c]
J 4164 c1 java.awt.Container.processEvent(Ljava/awt/AWTEventV java.desktop@10.0.1 (22 bytes) @ 0x000002ce0849459c [0x000002ce08494280+0x000000000000031c]
J 4231 c1 java.awt.Component.dispatchEventImpl(Ljava/awt/AWTEventV java.desktop@10.0.1 (777 bytes) @ 0x000002ce084bbc74 [0x000002ce084b80a0+0x0000000000003bd4]
J 4141 c1 java.awt.Container.dispatchEventImpl(Ljava/awt/AWTEventV java.desktop@10.0.1 (129 bytes) @ 0x000002ce0846e71c [0x000002ce0846e5e0+0x000000000000013c]
J 4142 c1 java.awt.Component.dispatchEvent(Ljava/awt/AWTEventV java.desktop@10.0.1 (6 bytes) @ 0x000002ce0846fbb4 [0x000002ce0846fac0+0x00000000000000f4]
j java.awt.LightweightDispatcher.retargetMouseEvent(Ljava/awt/Component;ILjava/awt/event/MouseEventV+349 java.desktop@10.0.1
J 4329 c1 java.awt.LightweightDispatcher.processMouseEvent(Ljava/awt/event/MouseEventZ java.desktop@10.0.1 (265 bytes) @ 0x000002ce084f6c5c [0x000002ce084f5d60+0x0000000000000efc]
J 4340 c1 java.awt.LightweightDispatcher.dispatchEvent(Ljava/awt/AWTEventZ java.desktop@10.0.1 (73 bytes) @ 0x000002ce084fda4c [0x000002ce084fd620+0x000000000000042c]
J 4141 c1 java.awt.Container.dispatchEventImpl(Ljava/awt/AWTEventV java.desktop@10.0.1 (129 bytes) @ 0x000002ce0846e6bc [0x000002ce0846e5e0+0x00000000000000dc]
J 4316 c1 java.awt.Window.dispatchEventImpl(Ljava/awt/AWTEventV java.desktop@10.0.1 (23 bytes) @ 0x000002ce084ec6ec [0x000002ce084ec120+0x00000000000005cc]
J 4223 c1 java.awt.EventQueue.dispatchEventImpl(Ljava/awt/AWTEvent;Ljava/lang/ObjectV java.desktop@10.0.1 (136 bytes) @ 0x000002ce084b0cdc [0x000002ce084b0840+0x000000000000049c]
и так далее
# Crash Report
и так далее
