И еще обсуждение миниПК
Что скажите об этом:
Welcome to the DragonBoard™ 410c
Coming summer 2015 DragonBoard™ 410c, will be the first development board based on a mid-tier Qualcomm® Snapdragon™ 400 series processor. Featuring the 64-bit capable Snapdragon 410 quad-core ARM® Cortex® A53 processor, the DragonBoard 410c supports Android, Linux and Windows 10 and offers advanced processing power, WiFi, Bluetooth, and GPS, all packed into a board the size of a credit card. It is designed to support feature-rich functionality, including multimedia, with the Adreno™ 306 GPU, integrated ISP with up to 13 MP camera support, and 1080p HD video playback and capture with H.264 (AVC).
The DragonBoard 410c is an ideal foundation for prototyping and includes LPDDR2/3 533MHz Single-channel 32-bit (4.2GBps) non-POP/ eMMC 4.51 SD 3.0 (UHS-I), as well as 1x 40 pin low speed and 1x 60 pin high speed expansion connectors, and analog expansion connector to support headsets, speakers and FM antenna. DragonBoard 410c has the rich feature set and mid-tier accessibility to enable wide-ranging embedded and Internet of Everything (IoE) applications, including the next generation of robotics, cameras, medical devices, vending machines, smart buildings, digital signage, casino gaming consoles, and much more.
https://www.96boards.org/products/dragonboard/
JustACat
nikolz, я лично без ценника (реального, за который можно купить от 1 штуки и с доставкой) ничего не скажу.
а как это за 78$
Cubieboard Cubie A10 1GB Arm Cortex-A8 Allwinner
The Cubieboard is a mini pc developer platform based on Allwinner A10, Compare with Raspberry Pi, it has a very wide range of IO options. The board is set apart by offering SATA and an extended pin interface for low level access to the SOC. The new one comes with a case. Also it has been proven to be more stable with less rejects when used with Rockminer products.
Specifications
CPU: 1G ARM cortex-A8 processor, NEON, VFPv3, 256KB L2 cache
GPU: Mali400, OpenGL ES GPU
Memory: 1GB DDR3 @480MHz
Video output: HDMI 1080p Output
Network: 10/100M Ethernet
Internal storage:4GB NAND Flash
IO ports: 2 USB Host, 1 micro SD slot, 1 SATA
Extended interfaces: 96 extend pin including I2C, SPI, RGB/LVDS, CSI/TS, FM-IN, ADC, CVBS, VGA, SPDIF-OUT, R-TP
Supports systems: Running Android, Ubuntu and other Linux distributions
Power supply:5VDC/2A power supply with 4.00mm(ext.diameter) x 1.7mm(int.diameter) barrel plug
Features
Allwinner A10 SOC
96 pin extended interface
Built-in IR receiver
SATA supported
Supports 2.4GHz wireless keyboard and mouse
http://www.ebay.com/itm/Cubieboard-...m-Development-Board-Kit-Mini-PC-/351345480236
JustACat
Ценник будет летом.
Вот тогда и обсудим :)
Ну, у меня CubieTruck. Брал за 100$ примерно, когда доллар еще был не конский.
100-ка за него - нормальная цена, но курс наш все портит конечно :(
На нем стоит вот этот вот образ серверный от Igor Pečovnik. Работает стабильно. В качестве сервера для разных дел - очень даже.
Если бы надо было голову в какую-то умную леталку/ездилку, то взял бы Hardkernel ODROID (какой-нибудь из, их несколько). Они дороже, но у них мощностей больше, это, например, если надо видео с камер обрабатывать для отслеживания объектов или типа того.
Ну а для многих более мелких вещей, как уже писал чуть ранее, хорошо подходят проверенные уже TP-Link за 20-ку на OpenWRT или даже совсем дешевские есть по 10-13 WiFi-3G - которые тоже перешиваются многие под OpenWRT.
В общем, смотря для чего. Все от задач зависит.
PS: Cubieboard тем более первый (A10) за 78 баксов - чего-то дороговато, имхо... Хотя по вашей же ссылке на ebay он всего за 38 - это другое дело конечно.
Примерно аналогичное у нас (Питер) раздают бесплатно :) Зашли платить провайдеру за инет - дали:
Там и БП и кабель есть, а цена = 0 :) OpenWRT встать должно.
http://baudlabs.com/broadcoms-bcm53...try-level-ieee-802-11n-retail-router-solution
А плату в начале темы заменяет любой планшетник и в ту-же цену входит ещё аккум, зарядка и экран :)
При уже мелкосерийном производстве никто готовую плату с разъемами использовать не будет - будут ставить модуль без разъемов, с разводкой их под свой корпус.
От этого цена таких, что указана в начале темы огромна - производство то штучное.
Модули без разъемов производятся китайцами тысячами и их цена в десятки раз менее.
я перешивкой роутеров занимался лет 10 назад.
Все хорошо, но Вы сравните потребление с ESP
или с модулем:
COMPONENTS
Processor
Ingenic dual-core M200 SoC, high performance (1.2 GHz) and low performance (300MHz) CPU.
- GPU: 3D with OpenGL ES 2.0/1.1 and OpenVG 1.1.
- VPU: H.264 720P@30fps encoding and decoding.
- ISP for image pre-processing.
Memory
eMCP H9TP32A4GDCCPR (4G byte eMMC + 4G bit LPDDR2).
PMIC
Ricoh RC5T619 power management IC.
Wi-Fi
Broadcom 43438 single-band 2.4GHz IEEE 802.11 b/g/n.
Bluetooth
Broadcom 43438 Bluetooth 4.1 (Bluetooth Low Energy), 2.1 + EDR.
Sensor
InvenSense MPU-9250, 9-axis gyroscope + accelerometer + magnetometer.
USB 2.0
Micro USB device.
UART Serial debug port.
Clocks 24MHz, 32.768kHz; 26MHz (Wi-Fi/BT).
EXTERNAL CONNECTORS
Display
1.63" 320 x 320 resolution AMOLED display (MIPI-DSI interface).
Touch
Capacitive touch screen.
Audio
DMIC and headphone.
Camera
OV9724 (MIPI-CSI interface), 1MP resolution, 720P@30fps.
Key
POWER_KEY, BOOT_SEL1, BOOT_KEY.
GPS and Sensor
UART, I2C, GPIO.
RF Connector
Wi-Fi and 2.4GHz BT antenna.
POWER Li-on battery: 3.7~4.2V; Micro USB: 5.0V.
Power consumption CPU full-working: 0.07mW/MHz.
Board standby: <3mW.
SOFTWARE Supported OS Android 4.4, Linux 3.10.
и это при объеме памяти в 4G byte eMMC + 4G bit LPDDR2
В прошлом году брал для разработки умных вещей.
забыл сказать размер платы 3 x 1.5 смxсм . стоит 100$
но в этом году уже вышли умные часы на основе этого кита можно взять по цене от 50$
в них либо датчики выкинуты либо память обрезана
Значит должны знать, что при реальной скорости в 2..3 раза и возможностях RAM/FLASH/ПОрты в 2..10 раз они потребляют менее ESP8266. Примерно на 10..20% в режиме полусна на 400..500MHz CPU :)
Даже старенький Atheros AR9330 - https://apollo.open-resource.org/lab:argus = 68 mA со всеми причендалами, а поновее и менее.
Итоговый выигрыш при средней исполняемой задаче по питанию примерно в 5 раз менее чем мучиться с жручим ESP8266 в 32 килобайтах памяти. :)
Народ всегда выбирает худшее из имеющегося...
Но на модулях с 32 и более Мегабайтами не интересно - там всё есть и работает.
Всё ненужное отключается. Как пример - samsung galaxy note 4 в режиме экстренного энергосбережения пашет от одной зарядки 1 месяц, а ресурсов там .... если на полную и трех часов не проработает...
недавно прочел новость, что к 2028 году полупроводниковая электроника себя исчерпает.
Настанет эра био электроники.
Майкрософт уже клепает программируемых бактерий и вирусов.
Это решим не мы, а полупроводники :)
Но как их питать от аккумуляторов и поместить в карман?
Для этого берут модули без разъемов и ставят в свой корпус, т.к. корпус обходится дороже модуля в мелкосерийке... Организация собственного монтажа тараканов тоже дорог для сотен изделий. По тому делают простую плату с разъемами под корпус, которую можно спаять на коленке, и на неё садят микромодуль... Думаю, что вы сами всё это знаете...
нет, ESP лучше(теоретически) либо модуль который я указал ранее (c 4GB)
  • Ingenic JZ4780, dual-core 1.2 GHz MIPS32 processor, PowerVR SGX540 GPU, 32k I&D L1 cache, 512k L2 cache
  • IEEE754 Floating Point Unit
  • 8 GB Flash, 1 GB DDR3 memory
  • Video playback up to 1080p
  • AC97 audio, via 4-pin input/output jack and HDMI connector
  • Camera interface – ITU645 controller
  • Connectivity – 10/100M Ethernet, 802.11 b/g/n, Bluetooth 4.0
  • HDMI output up to 2K resolution
  • 2 x USB – host and OTG
  • 14-pin EJTAG connector
  • 2 x UART, GPIO, SPI, I2C, ADC, expansion headers
цена 65$
http://store.imgtec.com/us/product/new-mips-creator-ci20/
цена 65$
Кошмар. Не растаможен, стоит дороже дешевого планшета с большей памятью, CPU, WiFi, Экраном, аккумулятором и зарядкой. :)
А Вы сами на таможню бегаете?
Что таможня, что нет - один цена 0 руб дополнительно
Это не ширпотреб а комплект для разработчиков (любителей паять и доделывать)
если хотите дешево, то есть у китайцев мобильники за 10 баксов а с андроидом за 20.
Чего на ней разрабатывать, если потом платить ещё раза в три больше + за сертификацию и т.д.?
У нас в стране продается только http://www.black-swift.ru для оф. разработки :)
