Вопрос как устранить утечку памяти
shavrin777
вот сервер что смог устранил , но память течёт
-- Close old Server
if httpd then
httpd:close()
httpd = nil
collectgarbage()
end
httpd=net.createServer(net.TCP)
-- decode URI
local function decodeURI(s)
    if(s) then
        s = string.gsub(s, '%%(%x%x)',
        function (hex) return string.char(tonumber(hex,16)) end )
    end
    return s
end
local function receive_http(sck, data)
  -- sendfile class
  sendfile = {}
  sendfile.__index = sendfile
  function sendfile.new(sck, fname)
    local self = setmetatable({}, sendfile)
    self.sck = sck
    self.fd = file.open(fname, "r")
    if self.fd then
       function send(localSocket)
        local response = self.fd:read(128)
        if response then
          localSocket:send(response)
        else
          if self.fd then
            self.fd:close()
          end
          localSocket:close()
        end
        response = nil
        collectgarbage()
      end
      self.sck:on("sent", send)
      send(self.sck)
    else
        localSocket:close()
    end
    localSocket = nil
    fname = nil
    collectgarbage()
    collectgarbage()
    return self
  end
  local host_name = string.match(data,"Host: ([0-9,\.]*)\r",1)
  local url_file = string.match(data,"[^/]*\/([^ ?]*)[ ?]",1)
  local uri = decodeURI(string.match(data,"[^?]*\?([^ ]*)[ ]",1))
  -- parse GET parameters
  local GET={}
  if uri then
    for key, value in string.gmatch(uri, "([^=&]*)=([^&]*)") do
     GET[key]=value
     print(key, value)
     key = nil
     value = nil
     cillectgarbage()
    end
  end
  -- parse POST parameters
  local post = string.match(data,"\n([^\n]*)$",1):gsub("+", " ")
  local POST={}
  if post then
    for key, value in string.gmatch(post, "([^=&]*)=([^&]*)") do
     POST[key]=decodeURI(value)
     print(key, POST[key])
     key = nil
     value = nil
     cillectgarbage()
    end
  end
  print("HTTP request:", data)
  request_OK = false
  -- if file not specified then send index.html
  if url_file == '' then
    sendfile.new(sck, 'index.html')
    self = nil
    sendfile = nil
    fext = nil
    sck = nil
    collectgarbage()
    request_OK = true
  else
    local fext=url_file:match("^.+(%..+)$")
    if fext == '.html' or
       fext == '.txt' or
       fext == '.js' or
       fext == '.json' or
       fext == '.css' or
       fext == '.png' or
       fext == '.gif' or
       fext == '.ico' then
       if file.exists(url_file) then
           sendfile.new(sck, url_file)
           self = nil
           sendfile = nil
           fext = nil
           url_file = nil
           sck = nil
           collectgarbage()
           request_OK = true
       end
    end
    -- execute LUA file
    -- IT IS HAZARDOUS
    if fext == '.lua' or fext == '.lc' then
        local response=dofile(url_file)
        sck:on("sent", function() sck:close() end)
        sck:send(response)
        response = nil
        self = nil
        sendfile = nil
        fext = nil
        sck = nil
        collectgarbage()
        request_OK = true
      end
    end
    fext = nil
  end
  if request_OK == false then
    sck:send('<html><h1>Error 404</h1></html>')
    sck = nil
  end
  response = nil
  data = nil
  POST = nil
  request_OK = nil
  post = nil
  self = nil
  fext = nil
  value = nil
  GET = nil
  key = nil
  host_name = nil
  url_file = nil
  uri = nil
  sck = nil
  collectgarbage()
  collectgarbage()
  collectgarbage()
  collectgarbage()
end
if httpd then
  httpd:listen(80, function(conn)
    conn:on("receive", receive_http)
    conn = nil
    collectgarbage()
  end)
end
Попробуйте изменить структуру программы
типа так:
сначала инициализация
потом запуск таймера в колбэке которого что-то делаете
а в колбеке сервера обработка ответа от сервера.
А то у вас какая-то странная программа для луа получилась нет цикла ожидания или колбека таймера.
