Не компилируется Web_base
amatron
Не компилируется Web_base:
c:/Espressif/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -Os -ffunction-sections -fno-jump-tables -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals    -I include -I ./ -I ../include -I ../include/  -o .output///obj/spi.o -c spi.c
In file included from ../include/driver/spi.h:6:0,
                 from spi.c:1:
spi.c: In function 'spi_slave_init':
../include/osapi.h:49:32: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'ICACHE_RODATA_ATTR'
  static const char flash_str[] ICACHE_RODATA_ATTR = fmt; \
spi.c:229:5: note: in expansion of macro 'os_printf'
     os_printf("SPI_CTRL2 is %08x\n",READ_PERI_REG(SPI_CTRL2(spi_no)));
../include/osapi.h:49:32: error: 'ICACHE_RODATA_ATTR' undeclared (first use in this function)
../include/osapi.h:49:32: note: each undeclared identifier is reported only once for each function it appears in
../include/osapi.h:50:17: error: 'flash_str' undeclared (first use in this function)
  os_printf_plus(flash_str, ##__VA_ARGS__); \
../Makefile:142: recipe for target '.output///obj/spi.o' failed
mingw32-make[1]: Leaving directory 'C:/Espressif/workspace/Web_base/driver'
mingw32-make[1]: *** [.output///obj/spi.o] Error 1
C:/Espressif/workspace/Web_base/Makefile:131: recipe for target '.subdirs' failed
mingw32-make.exe: *** [.subdirs] Error 2
22:43:14 Build Finished (took 20s.119ms)
В новой версии для UDK v1.0.8 (03.02.2015) директории Web_base/driver уже нет. Это значит, что вы используете старую версию с новой сборкой UDK от SHERTS
Прапор
pvvx, помогите пожалуйста разобраться с похожей проблемой :
03:37:39 **** Build of configuration Default for project Web_Base ****
mingw32-make.exe -f C:/Espressif/examples/esp8266web-0.4.9/Makefile all
mingw32-make[1]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app'
mingw32-make[2]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib'
mingw32-make[3]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/system'
mingw32-make[3]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/system'
mingw32-make[3]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/phy'
mingw32-make[3]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/phy'
mingw32-make[3]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/pp'
mingw32-make[3]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/pp'
mingw32-make[3]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/wpa'
mingw32-make[3]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/wpa'
mingw32-make[3]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip'
mingw32-make[4]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip/api'
mingw32-make[4]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip/api'
mingw32-make[4]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip/app'
mingw32-make[4]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip/app'
mingw32-make[4]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip/core'
mingw32-make[5]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip/core/ipv4'
mingw32-make[5]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip/core/ipv4'
mingw32-make[4]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip/core'
mingw32-make[4]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip/netif'
mingw32-make[4]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip/netif'
mingw32-make[3]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib/lwip'
mingw32-make[2]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/sdklib'
mingw32-make[2]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/user'
mingw32-make[2]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/user'
mingw32-make[2]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/driver'
mingw32-make[2]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/driver'
mingw32-make[2]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/mdbtcp'
mingw32-make[2]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/mdbtcp'
mingw32-make[2]: Entering directory 'C:/Espressif/examples/esp8266web-0.4.9/app/web'
mingw32-make[2]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app/web'
../Makefile:192: recipe for target '.output/eagle/bin/eagle.app.v6.bin' failed
process_begin: CreateProcess(NULL, C:/Python27/python.exe C:\Espressif\examples\esp8266web-0.4.9\esptool.py elf2image -o ../bin/ -ff 80m -fm qio -fs 4m .output/eagle/image/eagle.app.v6.out, ...) failed.
mingw32-make[1]: Leaving directory 'C:/Espressif/examples/esp8266web-0.4.9/app'
make (e=2): Не удается найти указанный файл.
mingw32-make[1]: *** [.output/eagle/bin/eagle.app.v6.bin] Error 2
C:/Espressif/examples/esp8266web-0.4.9/Makefile:240: recipe for target '.subdirs' failed
03:37:42 Build Finished (took 2s.790ms)
Что ему не нравится ?
Прапор
Наверно проект скопирован, а не импортирован в "Workspace" Eclipse.
Как импортировать указано в описании работы с UDK.
Папку "esp8266web-0.4.9" скопировал в заданную папку "Workspace" ("C:\Espressif\examples"), а потом в Эклипсе импортировал по инструкции - в "Project Explorer" появился проект "Web_Base". Далее в "Make Target" жму "all" или "clean" и потом "all" - никак :(
Удалил всё и сделал установку "с нуля". При первой же компиляции выдаёт это:
  File "C:\Espressif\examples\esp8266web-0.4.9\esptool.py", line 22, in <module>
  import serial
ImportError: No module named serial
mingw32-make[1]: *** [.output/eagle/bin/eagle.app.v6.bin] Error 1
06:05:53 Build Finished (took 2m:12s.756ms)
Tomahawk
Компилируется всё, научитесь работать с Eclipse для начала ) В Makefile можно найти строчку ESPTOOL ?= C:/Python27/python.exe $(CWD)esptool.py, а у вас его нет 100%.
