> Executing task: C:\Users\DNS\.platformio\penv\Scripts\platformio.exe run --target buildfs --environment esp_wroom_02 <
Processing esp_wroom_02 (platform: espressif8266; framework: esp8266-rtos-sdk; board: esp_wroom_02)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp_wroom_02.html
PLATFORM: Espressif 8266 (2.6.3) > ESP-WROOM-02
HARDWARE: ESP8266 80MHz, 80KB RAM, 2MB Flash
PACKAGES:
- framework-esp8266-rtos-sdk 1.5.0-beta.5
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-mklittlefs 1.203.210203 (2.3)
- tool-mkspiffs 1.200.0 (2.0)
- toolchain-xtensa 1.40802.0 (4.8.2)
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 0 compatible libraries
Scanning dependencies...
No dependencies
Building in release mode
AssertionError: :
File "C:\Users\DNS\.platformio\penv\Lib\site-packages\platformio\builder\main.py", line 178:
env.SConscript("$BUILD_SCRIPT")
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 591:
return _SConscript(self.fs, *files, **subst_kw)
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py", line 280:
exec(compile(scriptdata, scriptname, 'exec'), call_stack[-1].globals)
File "C:\Users\DNS\.platformio\platforms\espressif8266\builder\main.py", line 243:
target_firm = env.DataToBin(
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Environment.py", line 238:
return super().__call__(target, source, *args, **kw)
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Util.py", line 658:
return self.method(*nargs, **kwargs)
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Builder.py", line 650:
return self._execute(env, target, source, OverrideWarner(kw), ekw)
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Builder.py", line 560:
tlist, slist = self._create_nodes(env, target, source)
File "C:\Users\DNS\.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Builder.py", line 522:
target, source = self.emitter(target=tlist, source=slist, env=env)
File "C:\Users\DNS\.platformio\platforms\espressif8266\builder\main.py", line 119:
fetch_fs_size(env)
File "C:\Users\DNS\.platformio\platforms\espressif8266\builder\main.py", line 98:
assert all([
======================================= [FAILED] Took 3.75 seconds =======================================
Environment Status Duration
esp_wroom_02 FAILED 00:00:03.749
================================== 1 failed, 0 succeeded in 00:00:03.749 ==================================
The terminal process "C:\Users\DNS\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'buildfs', '--environment', 'esp_wroom_02'" terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
