14:29:44 **** Build of configuration Default for project blinky ****
mingw32-make.exe -f C:/Espressif/examples/blinky/Makefile flash
CC user/user_main.c
AR build/app_app.a
LD build/app.out
Section info:
build/app.out: file format elf32-xtensa-le
Sections:
Idx Name Size VMA LMA File off Algn
0 .data 00000374 3ffe8000 3ffe8000 000000e0 2**4
CONTENTS, ALLOC, LOAD, DATA
1 .rodata 00000100 3ffe8378 3ffe8378 00000458 2**3
CONTENTS, ALLOC, LOAD, READONLY, DATA
2 .bss 00006230 3ffe8478 3ffe8478 00000558 2**4
ALLOC
3 .text 00006732 40100000 40100000 00000558 2**2
CONTENTS, ALLOC, LOAD, READONLY, CODE
4 .irom0.text 0002d494 40240000 40240000 00006c90 2**4
Section| Description| Start (hex)| End (hex)|Used space
data| Initialized Data (RAM)| 3FFE8000| 3FFE8374| 884
rodata| ReadOnly Data (RAM)| 3FFE8378| 3FFE8478| 256
bss| Uninitialized Data (RAM)| 3FFE8478| 3FFEE6A8| 25136
text| Uncached Code (IRAM)| 40100000| 40106732| 26418
irom0_text| Cached Code (SPI)| 40240000| 4026D494| 185492
Entry Point : 40100004 call_user_start()
Total Used RAM : 26276
Free RAM : 55644
Free IRam : 6350 or 22734 if 48k IRam
Generate 0x00000.bin and 0x40000.bin successully in folder firmware.
0x00000.bin-------->0x00000
0x40000.bin-------->0x40000
Done
c:/Espressif/utils/esptool.exe -p COM3 -b 256000 write_flash -ff 40m -fm qio -fs 4m 0x00000 firmware/0x00000.bin 0x40000 firmware/0x40000.bin
File "esptool.py", line 566, in <module>
File "esptool.py", line 69, in __init__
File "serial\serialwin32.pyo", line 38, in __init__
File "serial\serialutil.pyo", line 282, in __init__
File "serial\serialwin32.pyo", line 66, in open
serial.serialutil.SerialException: could not open port 'COM3': WindowsError(2, '\xcd\xe5 \xf3\xe4\xe0\xe5\xf2\xf1\xff \xed\xe0\xe9\xf2\xe8 \xf3\xea\xe0\xe7\xe0\xed\xed\xfb\xe9 \xf4\xe0\xe9\xeb.')
C:/Espressif/examples/blinky/Makefile:220: recipe for target 'flash' failed
mingw32-make: *** [flash] Error 255
14:29:49 Build Failed. 2 errors, 0 warnings. (took 4s.139ms)
CC user/user_main.c
AR build/app_app.a
LD build/app.out
Section info:
Sections:
ALLOC
Free RAM : 55644
Done
