плохо работает датчик двери wifi
как я понял за кнопку отвечает скрипт sensor.lua. я расставил в нём команды вывода на печать текста lolNN чтобы понять где он зависает. выглядеть скрипт стал вот так
--sensor.lua
print("lol03")
file.open( "sensorThreshold.lua", "r" )
sensorThreshold = file.read()
sensorThreshold = string.gsub(sensorThreshold, "%s+", "")
sensorThreshold = tonumber(sensorThreshold)
file.close()
--Set how many times you'd like the sensor to receive an input before sending an alert.
print("lol04")
file.open( "timerThreshold.lua", "r" )
timerThreshold = file.read()
timerThreshold = string.gsub(timerThreshold, "%s+", "")
timerThreshold = tonumber(timerThreshold)*1000
file.close()
--print("Timer Reset: "..timerThreshold)
--The interaction of these two variables above will determine your tolerance for false alarms.
--For example if this device is a panic button and you want to send a message after 3 button presses within 10 seconds, set countThreshold = 3 and TimerResetThreshold = 10000.
--If this device is a Smoke Alarm Sound Sensor, and you want to wait until the alarm has been sounding for ~30 seconds before sending an alert, set countThreshold = 60, TimerResetThreshold = 60000 (60 loud sounds within 60 seconds).
--If this device is a Baby Noise SMS Alert, set countThreshold = 5, TimerResetThreshold = 60000 (5 loud sounds/cries within 60 seconds). Keep in mind you will have to calibrate your microphone sensor to a lower threshold than a Smoke Alarm Sensor.
buttonPin = 2 -- this is ESP-01 pin GPIO4
gpio.mode(buttonPin,gpio.INT,gpio.PULLUP)
count = 0
print("lol05")
function resetCounter()
    print("lol07")
    count = 0
    end
print("lol06")
function debounce (func)
    print("lol08")
    local last = 0
    local delay = 10000
    return function (bounceCheck)
        local now = tmr.now()
            if now - last < delay
            then return
            end
        last = now
        return func(bounceCheck)
    end
end
print("lol09")
function onChange()
    print("lol10")
    if gpio.read(buttonPin) == 0
    then count = count + 1
        tmr.alarm(6,timerThreshold,0,function()
        resetCounter()
        print("Time limit reached. Restarting Counter...")
        end)
            if count == sensorThreshold
            then
                print("(" .. count .. ") sensor inputs counted! Sending Alert!")
                dofile("ifttt.lua")
            else print("(" .. count .. ") sensor inputs counted...")
            end
    end
end
print("lol01")
gpio.trig(buttonPin,"down", debounce(onChange))
print("lol02")
вот как выглядит нормальное срабатываение сенора в терминале
[28/10/16 - 21:59:20:059] You are connected to Wifi. IP Address:192.168.1.42
[28/10/16 - 21:59:20:061] Starting Sensor...
[28/10/16 - 21:59:23:065] Listening for Sensor Inputs...
[28/10/16 - 21:59:23:093] lol03
[28/10/16 - 21:59:23:099] lol04
[28/10/16 - 21:59:23:105] pin,mode,pullup= 2 2 1
[28/10/16 - 21:59:23:109] Pin data at mode: 2 6000083c, 4 0 0, fffffffe
                          Function platform_gpio_mode() is called. pin_mux:1610614844, fu[28/10/16 - 21:59:23:115] nc:0
[28/10/16 - 21:59:23:115] lol05
[28/10/16 - 21:59:23:116] lol06
[28/10/16 - 21:59:23:119] lol09
[28/10/16 - 21:59:23:119] lol01
[28/10/16 - 21:59:23:119] lol08
[28/10/16 - 21:59:23:123] Pin data: 2 2 6000083c, 4 0 0, 00000002
[28/10/16 - 21:59:23:123] lol02
[28/10/16 - 21:59:28:067] pm open,type:2 0
[29/10/16 - 01:31:00:076] ip:192.168.1.42,mask:255.255.255.0,gw:192.168.1.1
[29/10/16 - 04:24:32:161] pin:2, level:0  <-- НАЖАЛ КНОПКУ[COLOR=#ff0000] [/COLOR]
[29/10/16 - 04:24:32:162] Calling: 00000002
[29/10/16 - 04:24:32:163] lol10
[29/10/16 - 04:24:32:172] (1) sensor inputs counted! Sending Alert!
[29/10/16 - 04:24:32:399] IFTTT Event Name: ALARM
[29/10/16 - 04:24:32:407] Sensor Type: BLA
[29/10/16 - 04:24:32:506] Sensor Location: BLA
[29/10/16 - 04:24:32:514] Sensor Location: MEDIUM
[29/10/16 - 04:24:32:517] net_create is called.
[29/10/16 - 04:24:32:519] TCP server/socket is set.
[29/10/16 - 04:24:32:520] net_on is called.
[29/10/16 - 04:24:32:522] net_on is called.
[29/10/16 - 04:24:32:532] net_dns is called.
[29/10/16 - 04:24:32:533] pin:2, level:1
[29/10/16 - 04:24:32:535] Calling: 00000002
[29/10/16 - 04:24:32:536] lol10  <---- НЕ ПОНИМАЮ КАК ЭТО МОЖЕТ БЫТЬ ВЕДЬ СЕЙЧАС ВЫПОЛНЯЕТСЯ СОВЕРШЕННО ДРУГОЙ СКРИПТ
[29/10/16 - 04:24:32:779] net_dns_found is called.
[29/10/16 - 04:24:32:786] We can connect to 54.88.106.208
[29/10/16 - 04:24:32:788] net_start is called.
[29/10/16 - 04:24:32:790] TCP port is set: 80.
[29/10/16 - 04:24:32:792] TCP ip is set: 54.88.106.208
[29/10/16 - 04:24:32:794] socket_connect is called.
[29/10/16 - 04:24:32:985] net_socket_connected is called.
[29/10/16 - 04:24:32:989] Sending to IFTTT
[29/10/16 - 04:24:32:995] Alert sent to IFTTT.
[29/10/16 - 04:24:33:206] net_socket_received is called.
[29/10/16 - 04:24:35:169] lol07
[29/10/16 - 04:24:35:176] Time limit reached. Restarting Counter...
[29/10/16 - 04:24:36:416] alertDelay: 10 minutes.
[29/10/16 - 04:24:36:423] Waiting 10 minutes before sending another message.
а вот как выглядит после зависания
[29/10/16 - 08:23:58:056] pin:2, level:1
[29/10/16 - 08:23:58:057] Calling: 00000002   <--- ЭТО МОУДУЛЬ ДЕЛАЕТ САМ ПО СЕБЕ
[29/10/16 - 08:23:58:057] lol10
[29/10/16 - 08:23:58:612] pin:2, level:1
[29/10/16 - 08:23:58:612] Calling: 00000002
[29/10/16 - 08:23:58:612] lol10
[29/10/16 - 08:36:49:933] pin:2, level:1
[29/10/16 - 08:36:49:933] Calling: 00000002
[29/10/16 - 08:36:49:933] lol10
[29/10/16 - 11:38:00:348] ip:192.168.1.42,mask:255.255.255.0,gw:192.168.1.1
[29/10/16 - 15:09:30:337] ip:192.168.1.42,mask:255.255.255.0,gw:192.168.1.1
[29/10/16 - 15:18:05:893] pin:2, level:1
[29/10/16 - 15:18:05:895] Calling: 00000002
[29/10/16 - 15:18:05:895] lol10    <--- ЭТО ОН САМ ТОЖЕ ЗАЧЕМ-ТО ДЕЛАЕТ
[29/10/16 - 15:25:10:730] pin:2, level:0  <--- А ВОТ ЭТО Я НАЧАЛ ЖАТЬ КНОПКУ
[29/10/16 - 15:25:10:732] Calling: 00000002
[29/10/16 - 15:25:10:734] pin:2, level:0   <--- НИ ОДНОГО ВЫВОДА lolNN
[29/10/16 - 15:25:10:736] Calling: 00000002
[29/10/16 - 15:25:23:752] pin:2, level:0
[29/10/16 - 15:25:23:753] Calling: 00000002
[29/10/16 - 15:25:23:891] pin:2, level:1
[29/10/16 - 15:25:23:891] Calling: 00000002
[29/10/16 - 15:25:23:999] pin:2, level:0
[29/10/16 - 15:25:24:000] Calling: 00000002
[29/10/16 - 15:25:24:002] pin:2, level:0
[29/10/16 - 15:25:24:003] Calling: 00000002
[29/10/16 - 15:25:24:141] pin:2, level:0
[29/10/16 - 15:25:24:142] Calling: 00000002
[29/10/16 - 15:25:24:217] pin:2, level:0
[29/10/16 - 15:25:24:218] Calling: 00000002
[29/10/16 - 15:25:24:220] pin:2, level:0
[29/10/16 - 15:25:24:221] Calling: 00000002
[29/10/16 - 15:25:24:332] pin:2, level:1
[29/10/16 - 15:25:24:333] Calling: 00000002
я по всему скрипту расставил выводы на печать так чтобы при выполнении любой функции или программы что-то да печаталось. но при зависании ничего не печается. так где же он зависает-то? :с
@shinji2009 как он может что то напечатать, если висит? Зависает после последнего вывода на экран. Там и копайте.
я просто думал что ну мало ли может после длительного простоя получается такая комбинация переменных при которых подпрограмма постинга ifttt не выполняется потому что до неё просто не доходит очередь. по выводу в терминал получается что программа зависает на команде
[inline]gpio.trig(buttonPin,"down", debounce(onChange))[/inline]
дебаг выдаёт что пин притягивается к нулю, но команде на это пофиг, она не срабатывает.
может кто-нибудь объяснить как в терминал выводится печать одного скрипта при работе другого? ([29/10/16 - 04:24:32:536])
и ещё поясните пожалуйста почему иногда в терминал выдаётся состояние пина (например [29/10/16 - 15:18:05:895]) это из-за статики?
я нашёл вот такой баг на гитхабе GPIO interrupts crash the device · Issue [HASHTAG]#874[/HASHTAG] · nodemcu/nodemcu-firmware · GitHub по описанию очень походит на то что имею я
решением написано использовать команду ICACHE_RAM_ATTR для работы с gpio
куда её надо вставить в скрипт?? куда ни вставляю - паника паника перезагрузко
поставил
[inline]ICACHE_RAM_ATTR = gpio.trig(buttonPin,"down", debounce(onChange))[/inline]
тестю
А зачем? Запись
-void gpio_intr_callback( unsigned pin, unsigned level )
+void ICACHE_RAM_ATTR gpio_intr_callback( unsigned pin, unsigned level )
Обозначает найти строку с ту, что после минуса и заменить на то, что после плюса.
Т.е. надо найти задание функции и поставить этот отрибут после типа функции. Ищите где задается gpio.trig() , а тут где Вы поправили она вызывается и подставлять атрибут, тем более таким странным образом, бессмысленно.
А зачем? Запись
вы можете поставить атрибут в скрипт куда надо? поставьте пожалуйста. я не знаю куда его ставить и как.
@shinji2009 не могу. Я тоже не знаю и скрипта у меня нет. Вам трудно поискать по тексту?
То что не будет виснуть, еще не факт, но Вы уж как нибудь сами, такие элементарные вещи делайте. Отладочный вывод ведь смогли поставить.
скрипт на этой же странице вверху, вот он плохо работает датчик двери wifi
в нем больше нет нигде gpio.trig
это нормально что модули постоянно перезагружюатся через 9:34 после выполнения своей функции?
взял кусок кода из другого проекта. не виснет. но зато в противовес сегодня ifttt падал и сейчас он глючит)
