* ESPRESSIF MIT License
* Copyright (c) 2017 <ESPRESSIF SYSTEMS (SHANGHAI) PTE LTD>
* Permission is hereby granted for use on ESPRESSIF SYSTEMS ESP8266 only, in which case,
* it is free of charge, to any person obtaining a copy of this software and associated
* documentation files (the "Software"), to deal in the Software without restriction, including
* without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the Software is furnished
* to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all copies or
* substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
* FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
* COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
* IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#include <stddef.h>
#include "openssl_demo.h"
#include "openssl/ssl.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "espressif/c_types.h"
#include "espressif/esp_misc.h"
#include "lwip/sockets.h"
#include "ssl_server_crt.h"
#define OPENSSL_DEMO_THREAD_NAME "ssl_demo"
#define OPENSSL_DEMO_THREAD_STACK_WORDS 2048
#define OPENSSL_DEMO_THREAD_PRORIOTY 6
Fragment size range 2048~8192
| Private key len | Fragment size recommend |
| RSA2048 | 2048 |
| RSA3072 | 3072 |
| RSA4096 | 4096 |
#define OPENSSL_DEMO_FRAGMENT_SIZE 2048
/* Local server tcp port */
#define OPENSSL_DEMO_LOCAL_TCP_PORT 443
#define OPENSSL_DEMO_REQUEST "{\"path\": \"/v1/ping/\", \"method\": \"GET\"}\r\n"
/* receive length */
#define OPENSSL_DEMO_RECV_BUF_LEN 1024
LOCAL xTaskHandle openssl_handle;
LOCAL char send_data[] = OPENSSL_DEMO_REQUEST;
LOCAL int send_bytes = sizeof(send_data);
LOCAL char recv_buf[OPENSSL_DEMO_RECV_BUF_LEN];
LOCAL void openssl_demo_thread(void* p)
int ret;
SSL_CTX* ctx;
SSL* ssl;
struct sockaddr_in sock_addr;
int sockfd, new_sockfd;
int recv_bytes = 0;
socklen_t addr_len;
printf("OpenSSL demo thread start...\n");
printf("create SSL context ......");
ctx = SSL_CTX_new(TLSv1_1_server_method());
if (!ctx) {
printf("failed\n");
goto failed1;
printf("OK\n");
printf("load ca crt ......");
X509* cacrt = d2i_X509(NULL, ca_crt, ca_crt_len);
if (cacrt) {
SSL_CTX_add_client_CA(ctx, cacrt);
printf("OK\n");
} else {
printf("failed\n");
goto failed2;
printf("load server crt ......");
ret = SSL_CTX_use_certificate_ASN1(ctx, server_crt_len, server_crt);
if (ret) {
printf("OK\n");
} else {
printf("failed\n");
goto failed2;
printf("load server private key ......");
ret = SSL_CTX_use_PrivateKey_ASN1(0, ctx, server_key, server_key_len);
if (ret) {
printf("OK\n");
} else {
printf("failed\n");
goto failed2;
printf("set verify mode verify peer\n");
// SSL_CTX_set_verify(ctx, SSL_VERIFY_PEER, NULL);
SSL_CTX_set_verify(ctx, SSL_VERIFY_NONE, NULL);
printf("set SSL context read buffer size ......OK\n");
SSL_CTX_set_default_read_buffer_len(ctx, OPENSSL_DEMO_FRAGMENT_SIZE);
printf("create socket ......");
sockfd = socket(AF_INET, SOCK_STREAM, 0);
if (sockfd < 0) {
printf("failed\n");
goto failed2;
printf("OK\n");
printf("socket bind ......");
memset(&sock_addr, 0, sizeof(sock_addr));
sock_addr.sin_family = AF_INET;
sock_addr.sin_addr.s_addr = 0;
sock_addr.sin_port = htons(OPENSSL_DEMO_LOCAL_TCP_PORT);
ret = bind(sockfd, (struct sockaddr*)&sock_addr, sizeof(sock_addr));
if (ret) {
printf("bind failed\n");
goto failed3;
printf("bind OK\n");
printf("server socket listen ......");
ret = listen(sockfd, 32);
if (ret) {
printf("failed\n");
goto failed3;
printf("OK\n");
reconnect:
printf("SSL server create ......");
ssl = SSL_new(ctx);
if (!ssl) {
printf("failed\n");
goto failed3;
printf("OK\n");
printf("SSL server socket accept client ......");
new_sockfd = accept(sockfd, (struct sockaddr*)&sock_addr, &addr_len);
if (new_sockfd < 0) {
printf("failed");
goto failed4;
printf("OK\n");
SSL_set_fd(ssl, new_sockfd);
printf("SSL server accept client ......");
ret = SSL_accept(ssl);
if (!ret) {
printf("failed\n");
goto failed5;
printf("OK\n");
do {
ret = SSL_read(ssl, recv_buf, OPENSSL_DEMO_RECV_BUF_LEN - 1);
if (ret <= 0) {
break;
recv_bytes += ret;
recv_buf[ret] = '\0';
printf("%s", recv_buf);
if (strstr(recv_buf, "\r\n\r\n") != 0) {
break;
} while (1);
char body[32];
char response[512];
static const char headers[] =
"HTTP/1.1 404 Not found\r\n"
"Server: esp8266\r\n"
"Content-Type: text/plain\r\n"
"Connection: close\r\n"
"Content-Length: %d\r\n\r\n";
sprintf(body, "FREE HEAP %d\r\n", (int)system_get_free_heap_size());
sprintf(response, headers, strlen(body));
strcat(response, body);
SSL_write(ssl, response, strlen(response));
vTaskDelay(2000 / portTICK_RATE_MS);
SSL_shutdown(ssl);
failed5:
close(new_sockfd);
new_sockfd = -1;
failed4:
SSL_free(ssl);
ssl = NULL;
goto reconnect;
failed3:
close(sockfd);
sockfd = -1;
failed2:
SSL_CTX_free(ctx);
ctx = NULL;
failed1:
vTaskDelete(NULL);
printf("task exit\n");
return ;
void user_conn_init(void)
int ret;
ret = xTaskCreate(openssl_demo_thread,
OPENSSL_DEMO_THREAD_NAME,
OPENSSL_DEMO_THREAD_STACK_WORDS,
NULL,
OPENSSL_DEMO_THREAD_PRORIOTY,
&openssl_handle);
if (ret != pdPASS) {
printf("create thread %s failed\n", OPENSSL_DEMO_THREAD_NAME);
return ;
