у меня есть рабочий скетч но,выход один (D4 )на датчик с виртуальным в блинке (V1) я хотел бы добавить еще два выхода независимых друг от друга например (D7иD8)с виводом в блинк (V2иV3)
#include <SimpleTimer.h> // Allows us to call functions without putting them in loop()
#define BLYNK_PRINT Serial // Comment this out to disable prints and save space
#include <OneWire.h>
#define ONE_WIRE_BUS 2 // Your ESP8266 pin (ESP8266 GPIO 2 = WeMos D1 Mini pin D4)
char auth[] = "yTZwFufou0Ii9niYqdynfWqUjRRtZ98F";
char ssid[] = "FASTWEB-B6EF73";
char pass[] = "MT9FP4Y4J2";
SimpleTimer timer;
int roomTemperature; // Room temperature in C
Serial.begin(9600);
while (Blynk.connect() == false) {
// Wait until connected
sensors.begin(); // Starts the DS18B20 sensor(s).
sensors.setResolution(10); // More on resolution: http://www.homautomation.org/2015/11/17/ds18b20-how-to-change-resolution-9101112-bits/
timer.setInterval(1000L, sendTemps); // Temperature sensor read interval. 2000 (ms) = 2 seconds.
// Notice how there is very little in the loop()? Blynk works best that way.
Blynk.run();
timer.run();
// Notice how there are no delays in the function below? Blynk works best that way.
void sendTemps()
sensors.requestTemperatures(); // Polls the sensors.
roomTemperature = sensors.getTempCByIndex(0); // Stores temperature. Change to getTempCByIndex(0) for celcius.
Blynk.virtualWrite(1, roomTemperature); // Send temperature to Blynk app virtual pin 1.
SimpleTimer timer;
Serial.begin(9600);
Blynk.run();
timer.run();
void sendTemps()
