Andrew0510
Здравствуйте, я новичок в этой сфере.
Есть скетч, сейчас читает температуру и влажность и постит в MQTT брокер.
Помогите дописать, чтобы можно было по MQTT включать/выключать реле.
Пин под реле прописал - 13 выход.
Спасибо
#include <PubSubClient.h>
#include <DHT.h>
#define wifi_ssid "TP-LINK_53A620"
#define wifi_password "10091993asd"
#define mqtt_server "server-adress"
#define mqtt_user "login"
#define mqtt_password "password"
#define humidity_topic "sensor/humidity"
#define temperature_topic "sensor/temperature"
#define DHTTYPE DHT11
#define DHTPIN 14
WiFiClient espClient;
PubSubClient client(espClient);
DHT dht(DHTPIN, DHTTYPE, 11); // 11 works fine for ESP8266
const int lamp = 13;
dht.begin();
setup_wifi();
client.setServer(mqtt_server, 19217);
pinMode(lamp, OUTPUT);
digitalWrite(lamp, LOW);
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.println(wifi_ssid);
WiFi.begin(wifi_ssid, wifi_password);
delay(500);
Serial.print(".");
Serial.println("");
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
// If you do not want to use a username and password, change next line to
// if (client.connect("ESP8266Client")) {
if (client.connect("ESP8266Client", mqtt_user, mqtt_password)) {
Serial.println("connected");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
bool checkBound(float newValue, float prevValue, float maxDiff) {
return !isnan(newValue) &&
(newValue < prevValue - maxDiff || newValue > prevValue + maxDiff);
long lastMsg = 0;
float temp = 0.0;
float hum = 0.0;
float diff = 1.0;
if (!client.connected()) {
reconnect();
client.loop();
long now = millis();
if (now - lastMsg > 2000) {
lastMsg = now;
float newTemp = dht.readTemperature();
float newHum = dht.readHumidity();
if (checkBound(newTemp, temp, diff)) {
temp = newTemp;
Serial.print("New temperature:");
Serial.println(String(temp).c_str());
client.publish(temperature_topic, String(temp).c_str(), true);
if (checkBound(newHum, hum, diff)) {
hum = newHum;
Serial.print("New humidity:");
Serial.println(String(hum).c_str());
client.publish(humidity_topic, String(hum).c_str(), true);
Спасибо
