feasycom
● FSC-BW236 is a RTL8720DN Chip BLE 5 & Wi-Fi Combo Module with low power consumption single-chip wireless solution, its Wi-Fi is dual bands(2.4GHz & 5GHz) and supports WLAN 802.11 a/b/g/n, Bluetooth version is BLE 5.0.
● Support communicating with the FeasyBlue app and many other Bluetooth apps
Basic Parameter
Customer can transfer data via UART, I2C and SPI interface, FSC-BW236 supports Bluetooth GATT profiles and Wi-Fi TCP, UDP, HTTP, HTTPS, and MQTT protocols, the Wi-Fi maximum data rate can up to 150Mbps in 802.11n, 54Mbps in 802.11g and 802.11a, it supports install an external antenna to increase wireless coverage.
FSC-BW236 Bluetooth & Wi-Fi combo module's parameters:
FSC-BW236 Main Features
FSC-BW236 Applications
Basic Parameter
| Module Model | FSC-BW236 |
| Wi-Fi | |
| Version | 802.11 a/b/g/n |
Transmit Power | 2.4GHz: 17.5dBm(11b), 15.5dBm(11g), 13.5dBm(11n) |
| 5GHz: 8dBm(11a) | |
| Bluetooth | |
| Version | BLE 5.0 |
| Transmit Power | +8dBm |
| Other Parameters | |
| Interfaces | UART, SPI, I2C |
| Power Supply | 3.0-3.6V |
| Dimension | 13mm x 26.9mm x 2.2mm |
| Operation Temperature | -20℃ to +85℃ |
| Storage Temperature | -55℃ to +125℃ |
| MSL Grade | MSL 3 |
