http://bbs.espressif.com/viewtopic.php?f=46&t=1442
Release Notes
Resolved Issues(Bugs below are eligible for Bug Bounty Program):
Release Notes
- Returned value of system_get_rst_info is wrong.
- Optimize espconn_regist_recvcb for UDP transmission.
- Print information will prompt errors if the input parameters of os_time_arm excess the upper limit.
- Optimize memory management.
- Optimize RF frequency offset.
- Print information will prompt errors if the size of bin file is too large in OTA.
- Optimize mDNS.
- Revise UART output print error when powered on again after call system_uart_swap.
- Revise errors during multiple UDP transmissions.
- Revise the error when wifi_station_set_config_default is called and the same AP is set as before, while information cannot be stored in the Flash.
- Optimize the error of packet loss during UDP transmission process under single station mode.
- Add new function, WPA2-Enterprise is supported.
- SmartConfig version is upgraded to V2.5.3.
- Mesh version is upgraded to V0.2.3.
- User application needs to add "-lcrypto" in 'LINKFLAGS_eagle.app.v6" area of Makefile.
- espconn_abort: break TCP connection compulsively.
- espconn_secure_delete: delete the SSL server when ESP8266 runs as SSL server.
- wifi_station_set_cert_key: set certificate and private key for WPA2 Enterprise.
- wifi_station_clear_cert_key: release the resouce of connecting to WPA2 Enterprise AP, and clear the status.
- Revise the error of the first byte in AT command when UART RX interrupt handler is implemented.
- Revise the malfunction of display when AT+CWLAP is invoked to scan a specific AP.
