WebServer CustomStepper
IgorFX
Доброго дня. Не могу разобраться где ошибка. Двигатель делает только один шаг по запросу.
#include <CustomStepper.h>
// -- USER EDIT --
const char* ssid     = "SweetHome";    // YOUR WIFI SSID
const char* password = "555555";    // YOUR WIFI PASSWORD
// change this to your motor if not NEMA-17 200 step
//#define STEPS 2048  // Max steps for one revolution
#define RPM 5     // Max RPM
#define DELAY 5    // Delay to allow Wifi to work
CustomStepper stepper(13, 12, 16, 14, (byte[]){8, B1000, B1100, B0100, B0110, B0010, B0011, B0001, B1001}, 4075.7728395, 12, CW);// -- END --
boolean uppoint = false;
boolean downpoint = false;
int STBY = 5;     // GPIO 5 TB6612 Standby
int LED = 2;      // GPIO 0 (built-in LED)
// GPIO Pins for Motor Driver board
//Stepper stepper(STEPS, 13, 12, 14, 16);
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
  stepper.setRPM(8);
  stepper.setSPR(4075.7728395);
  delay(5);
  // prepare onboard LED
  pinMode(LED, OUTPUT);
  digitalWrite(LED, HIGH);
  // prepare STBY GPIO and turn on Motors
  //pinMode(STBY, OUTPUT);
  //digitalWrite(STBY, HIGH);
  // Set default speed to Max (doesn't move motor)
  //stepper.setSpeed(RPM);
  // Connect to WiFi network
  Serial.print("STEPPER: Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    delay(500);
    Serial.print(".");
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
  // Blink onboard LED to signify its connected
blink();
blink();
    if (!client)
        return;
      String respMsg = "";    // HTTP Response Message
      Serial.println("new client");
      while(!client.available()){delay(1);}
      Serial.println(req);
      //client.flush();
   if (req.indexOf("/stepper/up") != -1)
         if (stepper.isDone() && uppoint == false)
        stepper.setDirection(CW);
        stepper.rotate(2);
        uppoint = true;
        //digitalWrite(STBY, LOW);
        blink();
        respMsg = "OK: MOTOR Going Up";
    if (req.indexOf("/stepper/down") != -1)
        if (stepper.isDone() && downpoint == false)
        stepper.setDirection(CCW);
        stepper.rotate(2);
        uppoint = false;
        downpoint = true;
        blink();
        respMsg = "OK: MOTOR Going Down";
        client.flush();
  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/plain\r\n\r\n";
  if (respMsg.length() > 0)
    s += respMsg;
  else
    s += "OK";
    s += "\n";
  // Send the response to the client
  client.print(s);
  delay(1);
  Serial.println("Client disconnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is detroyed
      // Match the request
  stepper.run();
void blink() {
  digitalWrite(LED, LOW);
  delay(500);
  delay(500);
gerkimuyda
По программе вы сами ей говорите срабатывать только один раз
[inline]if (stepper.isDone() && uppoint == false)[/inline] - сработать только, если вверх не работали
[inline]uppoint = true;[/inline] - отметить, что вверх уже срабатывали и больше не надо обрабатывать команду "вверх"
Тоже самое и "вниз".
Вы это имели ввиду? Или что-то другое?
IgorFX
И так пробовал. Делает шаг по запросу и все. Без разницы вверх или вниз запрос, шагает в одну сторону
gerkimuyda
Без [inline]{ }[/inline] условие выполняет только переключение [inline]stepper.setDirection()[/inline] - плохой тон писать так программы. Когда надо будет что-то дополнительно дописать - будете долго ловить ошибку, почему не работает.
Добавьте вывод отладочной инфы [inline]Serial.println();[/inline] и посмотрите, что там выводится у вас.
[inline]stepper.isDone()[/inline] - что выполняет (я с этой библиотекой не работал, не знаю)?
[inline]stepper.rotate(2);[/inline] - туда передается что? шаг? или угол поворота? Что даст [inline]stepper.rotate(2); stepper.rotate(4); stepper.rotate(2);[/inline]
kab
@IgorFX
Вы осознаёте, что по логике программы можно делать только по одному шагу, то в одну, то в другую сторону?
gerkimuyda
Не понятно, что вам надо. Попробуйте вариант постоянного вращения [inline]stepper.rotate();[/inline] без задания параметров
Также перепроверьте правильность подключения пинов, а то у вас там две настройки разных (одна наполовину закомментирована, лучше удалить ее совсем, чтобы не мешала и не вносила путаницу)
IgorFX
То есть движение есть, только вместо двух оборотов он поворачивается на меньший угол? В этом проблема?
Да он просто делает шаг, когда инструкция прописана на два оборота stepper.rotate(2). А stepper.run() должен её выполнить
kab
попробуй вместо
stepper.rotate(2)
вставить
stepper.rotateDegrees(720)
Похоже, в stepper.rotate(2) 2 - это стало число не оборотов, а шагов. Почему-то съехали так настройки.
gerkimuyda
Продолжаем набор на спиритические сеансы экстрасенсов :)))
Как думаете, что данная строка у вас выполняет?
[inline] if (!client) { return; } [/inline]
Я предполагаю, что она, наверное, не дает запускаться [inline]stepper.run()[/inline] а вы как считаете?
И еще, вам не кажется, что в приведенном тексте написано
двигатель за один оборот осуществляет 4075.7728395 шага. Данный двигатель поддерживает полушаговый режим и за один полный оборот может совершать 4076 шага,
А у вас полушаговый режим? И тут надо найти правильный вариант? (но это так, незначительный отступ от темы...)
