Arduino: 1.8.4 (Windows 7), Плата:"Generic ESP8266 Module, 80 MHz, 40MHz, DIO, 115200, 512K (64K SPIFFS), ck, Disabled, None"
C:\Users\user\Desktop\WiFiScan\WiFiScan.ino: In function 'void setup()':
WiFiScan:47: error: no matching function for call to 'File::write(String)'
logfile.write(WiFi.BSSIDstr(i));
C:\Users\user\Desktop\WiFiScan\WiFiScan.ino:47:37: note: candidates are:
In file included from C:\Users\user\Desktop\WiFiScan\WiFiScan.ino:1:0:
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src/SD.h:34:18: note: virtual size_t File::write(uint8_t)
virtual size_t write(uint8_t);
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src/SD.h:34:18: note: no known conversion for argument 1 from 'String' to 'uint8_t {aka unsigned char}'
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src/SD.h:35:18: note: virtual size_t File::write(const uint8_t*, size_t)
virtual size_t write(const uint8_t *buf, size_t size);
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src/SD.h:35:18: note: candidate expects 2 arguments, 1 provided
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src/SD.h:52:31: note: size_t File::write(T&) [with T = String; size_t = unsigned int]
template<typename T> size_t write(T &src){
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD\src/SD.h:52:31: note: no known conversion for argument 1 from 'String' to 'String&'
In file included from C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Stream.h:26:0,
from C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/HardwareSerial.h:31,
from C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Arduino.h:245,
from sketch\WiFiScan.ino.cpp:1:
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Print.h:62:16: note: size_t Print::write(const char*, size_t)
size_t write(const char *buffer, size_t size) {
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Print.h:62:16: note: candidate expects 2 arguments, 1 provided
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Print.h:56:16: note: size_t Print::write(const char*)
size_t write(const char *str) {
C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Print.h:56:16: note: no known conversion for argument 1 from 'String' to 'const char*'
Несколько библиотек найдено для "SD.h"
Используется: C:\Users\user\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD
Не используется: C:\arduino\libraries\SD
exit status 1
