Знатоки подскажите.
как мне отправить данные типа string, int?
понимаю, что отправка происходит в последнем абзаце
Но не понимаю, как подготовить данные к отправке.
Отправляются переменные sbuf, len. как преобразовать string и int в sbuf, len для отправки...
//how many clients should be able to telnet to this ESP8266
#define MAX_SRV_CLIENTS 2
const char* ssid = "2.4Ghz";
const char* password = "Qmu2vobq2@";
unsigned long currentTime;
unsigned long printtime;
WiFiServer server(23); // --> default port for communication usign TELNET protocol | Server Instance
WiFiClient serverClients[MAX_SRV_CLIENTS]; // --> Client Instanse
WiFi.begin(ssid, password);
// -->Try to connect to particular host for 20 times, If still not connected then automatically resets.
Serial.print("\nConnecting to "); Serial.println(ssid);
uint8_t i = 0;
while (WiFi.status() != WL_CONNECTED && i++ < 20) delay(500);
if(i == 21){
Serial.print("Could not connect to"); Serial.println(ssid);
while(1);
//start UART and the server
server.begin();
server.setNoDelay(true); // --> Won't be storing data into buffer and wait for the ack. rather send the next data and in case nack is received, it will resend the whole data
Serial.print("Ready! Use 'telnet ");
Serial.print(WiFi.localIP());
Serial.println(" 23' to connect");
uint8_t i;
//check if there are any new clients
if (server.hasClient())
for(i = 0; i < MAX_SRV_CLIENTS; i++)
//find free/disconnected spot
if (!serverClients[i] || !serverClients[i].connected())
if(serverClients[i]) serverClients[i].stop();
serverClients[i] = server.available();
Serial.print("New client: "); Serial.print(i);
continue;
//no free/disconnected spot so reject
WiFiClient serverClient = server.available();
serverClient.stop();
//check clients for data
for(i = 0; i < MAX_SRV_CLIENTS; i++){
if (serverClients[i] && serverClients[i].connected()){
if(serverClients[i].available()){
//get data from the telnet client and push it to the UART
while(serverClients[i].available()) Serial.write(serverClients[i].read());
//check UART for data
if(Serial.available()){
size_t len = Serial.available();
uint8_t sbuf[len];
Serial.readBytes(sbuf, len);
//push UART data to all connected telnet clients
serverClients[i].write(sbuf, len);
delay(1);
uint8_t sbuf[len];
delay(1);
