Нужна помощь запросы c WEB сервера
DRC
Добрый день!
Помогите, пожалуйста разобраться в проблеме:
есть Web server на esp8266 который управляет реле в режиме on/off
const char* ssid     = "xxx";
const char* password = "xxx";
WiFiServer server(80);
String header;
String output5State = "off";
const int output5 = 5;
// устанавливаем mac адрес устройства
void initVariant() {
  uint8_t mac[6] = {0x00, 0xA3, 0xA0, 0x1C, 0x8C, 0x45};
  wifi_set_macaddr(STATION_IF, &mac[0]);
pinMode(output5, OUTPUT);
digitalWrite(output5, LOW);
  // Connect to Wi-Fi network with SSID and password
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  // Print local IP address and start web server
  Serial.println("");
  Serial.println("WiFi connected.");
  server.begin();
void loop(){
  if (client) {                            ,
    Serial.println("New Client.");
    String currentLine = "";
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        header += c;
        if (c == '\n') {
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            // включаем-выключаем реле
            if (header.indexOf("GET /5/on") >= 0) {
              Serial.println("GPIO 5 on");
              digitalWrite(output5, HIGH);
              output5State = "on";
            } else if (header.indexOf("GET /5/off") >= 0) {
              Serial.println("GPIO 5 off");
            //HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // CSS to style the on/off buttons
            // Feel free to change the background-color and font-size attributes to fit your preferences
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            client.println(".button2 {background-color: #77878A;}</style></head>");
            // Web Page Heading
            client.println("<body><h1>ESP8266 Web Server</h1>");
            // Display current state, and ON/OFF buttons for GPIO 5
            client.println("<p>GPIO 5 - State " + output5State + "</p>");
            // If the output5State is off, it displays the ON button
            if (output5State=="off") {
              client.println("<p><a href=\"/5/on\"><button class=\"button\">ON</button></a></p>");
            } else {
              client.println("<p><a href=\"/5/off\"><button class=\"button button2\">OFF</button></a></p>");
              client.println();
            // Break out of the while loop
            break;
          } else { // if you got a newline, then clear currentLine
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;
    header = "";
    client.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
при просто работе с WEB все работает как надо.
При попытке соединить это с HomeBridge возникает проблема, решение которой не нашел в силу отсутствия глубоких знаний.
Использую плагин:
Powerful http switch for Homebridge (Supereg/homebridge-http-switch)
            "accessory": "HTTP-SWITCH",
            "name": "Switch",
            "switchType": "stateful",
            "debug": true,
            "onUrl": {
                "url": "http://10.0.1.21/5/on",
                "method": "GET"
            "offUrl": {
                "url": "http://10.0.1.21/5/off",
                "method": "GET"
            "statusUrl": {
                "url": "http://10.0.1.21/output5State",
                "method": "GET"
для определения состояния выключателя был использован параметр output5State. Но состояние не изменятся не важно какой метод был выбран или какие значения "on" или 1 были присвоены в коде esp
Сам выключатель работает как из WEB так и из HomeKit но в HomeKit не запоминает состояния которое на устройстве если преложение закрыть и открыть снова
Отсюда вопрос, что не так или где можно на примерах посмотреть как надо делать и как это должно работать?
remrum
Сделайте отдельный обработчик запроса статуса http://10.0.1.21/output5State
Пример как сделать есть здесь.
Плагину homebridge отдавайте статус в виде 0 или 1.
Для обновления статуса в homekit попробуйте для начала метод периодического опроса указав в настройке pullInterval.
Все описано на странице плагина.
Но даже не используя дополнительный опрос, homekit делает запрос статуса при открытии приложения.
DRC
получается я создаю запрос вида:
server.on("/stat", sendServer);
и делаю модуль ответа с условиями:
// Отправляем серверу события ручного вкл./выкл.
void sendServer(){
if(lamp_on == true) {
    server.send(200, "text/plain", "1");
      } else {
    server.send(200, "text/plain", "0");
если через браузер провеляю команду localhost/stat то получаю ответ 1 или 0, но homedridge по прежнему не видит состояние
remrum
homebridge-http-switch передает состояние каждый раз когда открывается интерфейс "Дом".
В чем можно легко убедится поменяв состояние и закрыв/открыв "Дом".
Для того что-бы в реальном времени видеть статус переключателя добавьте в конфиг строчку: "pullInterval": 1000,
И получите обновление каждую секунду.
Но это не самый хороший способ. Есть и другие - сервер уведомлений, websocket.
Ещё раз повторю, все описано на странице плагина.
