// Test for ESP8266 WPS connection.
// WPS works in STA (Station mode) only.
WiFi.mode(WIFI_STA);
delay(1000);
// Called to check if SSID and password has already been stored by previous WPS call.
// The SSID and password are stored in flash memory and will survive a full power cycle.
// Calling ("",""), i.e. with blank string parameters, appears to use these stored values.
WiFi.begin("","");
// Long delay required especially soon after power on.
delay(4000);
// Check if WiFi is already connected and if not, begin the WPS process.
if (WiFi.status() != WL_CONNECTED) {
Serial.println("\nAttempting connection ...");
WiFi.beginWPSConfig();
// Another long delay required.
delay(3000);
if (WiFi.status() == WL_CONNECTED) {
Serial.println("Connected!");
Serial.println(WiFi.SSID());
Serial.println(WiFi.macAddress());
else {
Serial.println("Connection failed!");
else {
Serial.println("\nConnection already established.");
// put your main code here, to run repeatedly:
