В образце WiFiTelnetToSerial чтобы все заработало нужно заменить везде Serial1.println на Serial.println.
Вот код с исправлениями , который у меня на ESP-12F наконец-то заработал.
//how many clients should be able to telnet to this ESP8266
#define MAX_SRV_CLIENTS 100
const char* ssid = "имя точки доступа";
const char* password = "пароль";
WiFiServer server(23);
WiFiClient serverClients[MAX_SRV_CLIENTS];
pinMode(2, OUTPUT);
WiFi.begin(ssid, password);
Serial.print("\nConnecting to "); Serial.println(ssid);
uint8_t i = 0;
while (WiFi.status() != WL_CONNECTED && i++ < 20) delay(500);
if(i == 21){
Serial.print("Could not connect to"); Serial.println(ssid);
while(1) delay(500);
//start UART and the server
server.begin();
server.setNoDelay(true);
Serial.print("Ready! Use 'telnet ");
Serial.print(WiFi.localIP());
Serial.println(" 23' to connect");
digitalWrite(2, LOW);
uint8_t i;
//check if there are any new clients
if (server.hasClient()){
for(i = 0; i < MAX_SRV_CLIENTS; i++){
//find free/disconnected spot
if (!serverClients || !serverClients.connected()){
if(serverClients) serverClients.stop();
serverClients = server.available();
Serial.print("New client: "); Serial.print(i);
continue;
//no free/disconnected spot so reject
WiFiClient serverClient = server.available();
serverClient.stop();
//check clients for data
if (serverClients && serverClients.connected()){
if(serverClients.available()){
//get data from the telnet client and push it to the UART
while(serverClients.available()) Serial.write(serverClients.read());
//check UART for data
if(Serial.available()){
size_t len = Serial.available();
uint8_t sbuf[len];
Serial.readBytes(sbuf, len);
//push UART data to all connected telnet clients
serverClients.write(sbuf, len);
delay(1);
pinMode(2, OUTPUT);
uint8_t i = 0;
if(i == 21){
server.begin();
uint8_t i;
continue;
uint8_t sbuf[len];
delay(1);
