#include <endian.h>
#include <stdbool.h>
#include <stdlib.h>
#include <stdio.h>
#include <sys/socket.h>
#include <unistd.h>
#include "bluetooth/bluetooth.h"
#include "bluetooth/hci.h"
#define NEW_LE_AUTOCONN_TIMEOUT 22000
struct hci_event {
uint16_t code;
uint16_t controller_id;
uint16_t size;
uint16_t cmd_opcode;
uint8_t cmd_status;
#define EVT_CODE_CMD_COMPLETE 0x0001
#define EVT_CMD_STATUS_SUCCESS 0x00
#define PARAM_TYPE_LE_AUTOCONN_TIMEOUT 0x001b
unsigned char read_buf[1024];
const unsigned char read_conf_cmd[6] = {
0x4b, 0x00,
0x00, 0x00,
0x00, 0x00};
unsigned char set_le_autoconn_timeout_cmd[] = {
0x4c, 0x00,
0x00, 0x00,
0x05, 0x00,
0x1b, 0x00, 0x02, 0x00, 0x00
const int set_timeout_cmd_value_offset = 9;
int get_autoconn_timeout_from_result(const unsigned char *buf, size_t size)
buf += 6;
const unsigned char * const buf_end = buf + size;
while (buf < buf_end) {
uint16_t param_type = le16toh(*(uint16_t *)buf);
uint8_t param_data_size = *(uint8_t *)(buf + 2);
if (param_type == PARAM_TYPE_LE_AUTOCONN_TIMEOUT) {
uint16_t value;
switch (param_data_size) {
case 1:
value = *(uint8_t *)(buf+3);
break;
case 2:
value = le16toh(*(uint16_t *)(buf+3));
break;
default:
fputs("Unexpected value length", stderr);
return -1;
printf("LE Autoconnect Timeout=%d \n", value);
return value;
buf += 2 + 1 + param_data_size;
puts("Param type LE Autoconnect Timeout not found in result");
return -1;
void print_buf(const unsigned char *buf, size_t len)
for (int i = 0; i < len; i++) {
printf("%02X ", (unsigned)buf[i]);
puts("");
bool is_read_only_param(char *param)
static const char read_param[]= "--read";
return strncmp(param, read_param, sizeof(read_param)) == 0;
struct hci_event *get_event_from_buf(void *buf)
struct hci_event *evt = malloc(sizeof(struct hci_event));
if (!evt)
exit(EXIT_FAILURE);
memcpy(evt, buf, sizeof(*evt));
evt->code = le16toh(evt->code);
evt->controller_id = le16toh(evt->controller_id);
evt->size = le16toh(evt->size);
evt->cmd_opcode = le16toh(evt->cmd_opcode);
return evt;
int set_le_autoconn_timeout(int sockfd, uint16_t new_val)
int status, result;
struct hci_event *event;
new_val = htole16(new_val);
memcpy(
&set_le_autoconn_timeout_cmd[set_timeout_cmd_value_offset], &new_val, sizeof(new_val)
status = send(sockfd, set_le_autoconn_timeout_cmd, sizeof(set_le_autoconn_timeout_cmd), 0);
if (status < 0) {
perror("Failed to set params");
return -1;
memset(read_buf, 0, sizeof(read_buf));
status = recv(sockfd, read_buf, sizeof(read_buf), 0);
if (status < 0) {
return -1;
event = get_event_from_buf(read_buf);
result = (event->code == EVT_CODE_CMD_COMPLETE
&& event->size >= 3
&& event->cmd_status == EVT_CMD_STATUS_SUCCESS
) ? 0 : -1;
free(event);
if (result)
print_buf(read_buf, status);
return result;
int main(int argc, char *argv[static 1])
int status;
struct sockaddr_hci addr = {0};
int sockfd = socket(AF_BLUETOOTH, SOCK_RAW | SOCK_CLOEXEC, BTPROTO_HCI);
if (sockfd < 0) {
perror("socket create error");
return EXIT_FAILURE;
addr.hci_family = AF_BLUETOOTH;
addr.hci_dev = HCI_DEV_NONE;
addr.hci_channel = HCI_CHANNEL_CONTROL;
status = bind(sockfd, (struct sockaddr *)&addr, sizeof(addr));
if (status < 0) {
perror("socket bind failed");
close(sockfd);
status = send(sockfd, read_conf_cmd, sizeof(read_conf_cmd), 0);
if (status < 0) {
perror("socket write failed");
close(sockfd);
status = recv(sockfd, read_buf, 1024, 0);
if (status <= 0) {
perror("Didn't receive response");
close(sockfd);
struct hci_event *event = get_event_from_buf(read_buf);
if (event->code == EVT_CODE_CMD_COMPLETE && event->cmd_status == EVT_CMD_STATUS_SUCCESS) {
int autocon_timeout;
printf("Command complete, result size: %hu.\nBinary response: \n", event->size);
autocon_timeout = get_autoconn_timeout_from_result(read_buf, event->size);
if (autocon_timeout < 0) {
if (argc < 2 || !is_read_only_param(argv[1])) {
printf("Set new LE Autoconnect Timeout value to %d... ", NEW_LE_AUTOCONN_TIMEOUT);
if (set_le_autoconn_timeout(sockfd, NEW_LE_AUTOCONN_TIMEOUT) == 0) {
puts("OK");
} else {
puts("ERROR");
} else {
fputs("Could not read current settings\n", stderr);
free(event);
close(sockfd);
return EXIT_SUCCESS;
