Обсуждение Программатор для TLSR
G0V
The E180-Z6907A Modul has 12Mhz Osci but the bytepatched BDT firmware expects 16Mhz so it will not run and needs further tweaking or the replacement of the Osci to 16Mhz
It is indeed unable to run directly. I burned the firmware "evk8269v3.5.pb0-sws.bin" to the E180-Z6907A module using the "TLSR Tool ver 0.0.1.6" PC software through the STM32F103C8T6 (USB2Swire-STM32F103C8-v06.hex). The black and red power wires of the USB data cable are connected to a 3.3V linear regulator, which then powers the E180-Z6907A module. The green wire of the USB data cable is connected to the PE3/DP of the E180-Z6907A module, and the white wire is connected to the PE2/DM. Then, the USB-A plug is inserted into the PC's USB interface. A prompt pops up in the bottom right corner of the PC:
After clicking:
How to modify "evk8269v3.5.pb0-sws.bin" to make its working frequency match the 12MHz of E180-Z6907A?
Note: I have already soldered and attached the module's shield to the motherboard, if you want to replace the crystal of the E180-Z6907A module, it will be more troublesome to disassemble the shield.
:unsure:
Firmware v3.5 for BDT is a very old version. Current firmware version for BDT is ver4.6.
To work with the old version of FW you will need the old version of BDT program.
I modified the binary code of the v3.5 firmware by disassembling it in "Ghidra". Then by manually changing and inserting the binary code responsible for the frequencies of the quartz and pins.
It was over 6 years ago and nothing was saved. And there was nothing to save - I modified the binary file manually in HEX format...
EVK-BDT has a 12 MHz quartz.
If the module has a 12 MHz quartz, it means that fewer patches of the original firmware from Telink-EVK are required.
The latest firmwares versions are located in the "BDT\config\fw" directory after installing BDT.
There are no debugging functions for IDE in BDT. There is only a primitive interface for outputting values from memory via a MAP file and a CPU stop function. This is not an analogue of the functionality of other MCUs via Jtag. This is a very primitive function in BDT, with which it is impossible to debug.
All BDT functions, except for the unnecessary interface for outputting values from memory via a MAP file, are implemented in TLSRPGM. If you know Python, you can also add debugging, since the TLRPGM firmware has all the functions for this.
And TLSRPGM works much faster than BDT-EVK. It is more difficult to work with BDT when flashing various thermometers and other ready-made devices.
That is why I do not use BDT-EVK.
G0V
Why do you need a BDT emulator anyway?
Okay, thanks for sharing the related materials about reverse engineering TC32.
I haven't used Telink BDT.exe before, so I want to try it out. I just started learning about the TLSR8258 chip two weeks ago and need to use it to implement some simple functions. Therefore, I began to learn about information related to the TLSR8258. Since I haven't used the software tools before, I want to try them out and experience the fun of trying new things and tinkering with them.
G0V
I also bought the TB-03F-KIT development board at the same time, and when I have time, I will try TLSRPGM.
Yes, Python scripts can be used to write some customized functions with the assistance of DeepSeek
G0V
When importing evk8269v3.5.pb0-sws.bin into Ghidra, which "Language" should be chosen? The contents of cmp32.txt and cmp35.txt are all about what, can't understand
G0V
[引用="pvvx, 帖子: 100267, 用户: 6"]
BDT 中没有针对 IDE 的调试功能。仅有一个通过 MAP 文件从内存输出值的原始接口和 CPU 停止功能。这与其他 MCU 通过 Jtag 实现的功能并不等同。BDT 中的这项功能非常基础,无法用于实际调试。
除了通过 MAP 文件从内存输出值的非必要接口外,BDT 的所有功能已在 TLSRPGM 中实现。若您熟悉 Python,还可添加调试功能,因为 TLRPGM 固件已包含相关支持。
且 TLSRPGM 的运行速度远超 BDT-EVK。在烧录各类温度计等成品设备时,使用 BDT 更为繁琐。
正因如此,我选择不使用 BDT-EVK。
[/引用结束]
