Electronic Components--Resistor
Timuring
For engineers in the electronics industry, electronic components are the basic element. There are several types of components, in this artical,I would like to share some basic knowledge about resistors.
Resistor is the most frequently used in all electronic circuits. Resistor is called a resistive material because it has a hindrance to the current. It can cause changes in electron flux. The smaller the resistor, the greater the flux of electrons and vice versa.
Most of the time, the resistors we used are with fixed values. For example,
Wire Wound Resistor can be made as a precision resistor with a tolerance of 0.005% and a very low temperature coefficient.The disadvantage is that the parasitic inductance of the wire wound resistor is relatively large and cannot be used for high frequencies. The volume of the wire wound resistor can be made very large, and then an external heat sink can be used as a high power resistor.
Carbon Composition Resistor is simple in process and easy to obtain raw materials, so the price is the cheapest. However, the performance of the carbon composite resistor is not so good, the tolerance is relatively large (that is, the precision resistor cannot be made), the temperature characteristics are not good, and the noise is usually large.
Carbon Film Resistor mainly forms a carbon mixture film on the ceramic rod, for example, directly coating a layer, the thickness of the carbon film and the carbon concentration thereof can control the size of the resistor.
I would appreciate it if you can complement more types.
Электронные компоненты - резистор
Для инженеров в электронной промышленности электронные компоненты являются основным элементом. Есть несколько типов компонентов, в этой статье я хотел бы поделиться некоторыми базовыми знаниями об резисторах.
Резистор является наиболее часто используемым во всех электронных схемах. Резистор называется резистивным материалом, потому что он имеет помехи для тока. Это может вызвать изменения в потоке электронов. Чем меньше резистор, тем больше поток электронов и наоборот.
В большинстве случаев используемые нами резисторы имеют фиксированные значения. Например,
Резистор с проволочной обмоткой может быть выполнен как прецизионный резистор с допуском 0,005% и очень низким температурным коэффициентом. Недостатком является то, что паразитная индуктивность проволочного обмоточного резистора относительно велика и не может использоваться для высоких частот. Объем проволочного резистора может быть очень большим, и тогда внешний радиатор можно использовать в качестве резистора большой мощности.
Углеродный состав резистор прост в процессе и легко получить сырье, поэтому цена является самой дешевой. Однако характеристики углеродного композитного резистора не так хороши, допуск относительно велик (то есть прецизионный резистор не может быть изготовлен), температурные характеристики не являются хорошими, а шум обычно велик.
Углеродный пленочный резистор в основном образует пленку углеродной смеси на керамическом стержне, например, непосредственно покрывая слой, толщина углеродной пленки и его концентрация углерода могут контролировать размер резистора.
Буду признателен, если вы можете дополнить больше типов.
