Нужна помощь esp-12e
Ильнар
Здравствуйте.
Заказал разные esp8266 платы Esp8266 esp-12e, и NodeMcu Lua. Прошивал через arduino ide
// Including the ESP8266 WiFi library
#include "DHT.h"
// Uncomment one of the lines below for whatever DHT sensor type you're using!
//#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
// Replace with your network details
const char* ssid = "*********";
const char* password = "*********";
// Web Server on port 80
WiFiServer server(80);
// DHT Sensor
const int DHTPin = 1;
// Initialize DHT sensor.
DHT dht(DHTPin, DHTTYPE);
// Temporary variables
static char celsiusTemp[7];
static char fahrenheitTemp[7];
static char humidityTemp[7];
// only runs once on boot
  // Initializing serial port for debugging purposes
  delay(10);
  dht.begin();
  // Connecting to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  // Starting the web server
  server.begin();
  Serial.println("Web server running. Waiting for the ESP IP...");
  delay(10000);
  // Printing the ESP IP address
// runs over and over again
  // Listenning for new clients
  if (client) {
    Serial.println("New client");
    // bolean to locate when the http request ends
    boolean blank_line = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (c == '\n' && blank_line) {
            // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
            float h = dht.readHumidity();
            // Read temperature as Celsius (the default)
            float t = dht.readTemperature();
            // Read temperature as Fahrenheit (isFahrenheit = true)
            float f = dht.readTemperature(true);
            // Check if any reads failed and exit early (to try again).
            if (isnan(h) || isnan(t) || isnan(f)) {
              Serial.println("Failed to read from DHT sensor!");
              strcpy(celsiusTemp,"Failed");
              strcpy(fahrenheitTemp, "Failed");
              strcpy(humidityTemp, "Failed");
            else{
              // Computes temperature values in Celsius + Fahrenheit and Humidity
              float hic = dht.computeHeatIndex(t, h, false);
              dtostrf(hic, 6, 2, celsiusTemp);
              float hif = dht.computeHeatIndex(f, h);
              dtostrf(hif, 6, 2, fahrenheitTemp);
              dtostrf(h, 6, 2, humidityTemp);
              // You can delete the following Serial.print's, it's just for debugging purposes
              Serial.print("Humidity: ");
              Serial.print(h);
              Serial.print(" %\t Temperature: ");
              Serial.print(t);
              Serial.print(" *C ");
              Serial.print(f);
              Serial.print(" *F\t Heat index: ");
              Serial.print(hic);
              Serial.print(hif);
              Serial.print(" *F");
              Serial.print(h);
              Serial.print(t);
              Serial.print(f);
              Serial.print(hic);
              Serial.print(hif);
              Serial.println(" *F");
            client.println("Content-Type: text/html");
            client.println("Connection: close");
            client.println();
            // your actual web page that displays temperature and humidity
            client.println("<!DOCTYPE HTML>");
            client.println("<html>");
            client.println("<head></head><body><h1>ESP8266 - Temperature and Humidity</h1><h3>Temperature in Celsius: ");
            client.println(celsiusTemp);
            client.println("*C</h3><h3>Temperature in Fahrenheit: ");
            client.println(fahrenheitTemp);
            client.println("*F</h3><h3>Humidity: ");
            client.println(humidityTemp);
            client.println("%</h3><h3>");
            client.println("</body></html>");
            break;
        if (c == '\n') {
          // when starts reading a new line
          blank_line = true;
        else if (c != '\r') {
          // when finds a character on the current line
          blank_line = false;
    // closing the client connection
    delay(1);
    client.stop();
    Serial.println("Client disconnected.");
Оба прошиваются без проблем, сервер запускается.Только на плате Lua данные с датчика идут а на esp-12 нет, ошибка. На вид они одинаковые...
А то, что esp-12 без обвески не напрягает?
А так, как всегда питание и другое. Ошибку тоже угадывать?
Ильнар
Как таковой ошибки нет в работе платы и сервера нет данных с датчика...на другом есть.
Разобрался.Пользовался USB удлинителем, оказалось ток сажает...
Спасибо за подсказку.
Юрий Ботов
Питание платы esp? Наличие на плате 1117 распаянного на обратной стороне белой платы?
Наличие преобразователей уровня между esp и датчиком?
Acute
А можно же датчик запитать от 3,3В и не делать делитель напряжения? По даташиту он питается от 3 до 5,5В. Не то, чтобы призываю или стараюсь сэкономить на резисторах, просто интересно :)
