ESP +UDP = Exception (3)
DrJarold
ESP работает в режиме моста UDP-UART-UDP. Фактически просто пробрасывая сообщения с порта UDP на Serial Arduino ожидая пока та ответит и возвращает ответ в UDP. Вот код:
#define MAX_BUFFER 1000
#define UTC3 10800            //UTC+3
#define DELAY_MESSAGE_UPDATE 10000
#define DELAY_NTP_UPDATE 3600000        // 10 minutes
unsigned long timeIP, lastNTPtime, currentNTPtime;
bool NTPState = false;
bool WIFI_ENABLE = false;
byte MAX_TIMERS = 8;
byte MAX_TEMP_SENSOR = 4;
bool isWaitResponse = false;
bool isError = false;
bool isSettingsApply = false;
unsigned int localUdpPort = 8888;
char incomingPacket[MAX_BUFFER];
int NTP_ADDR = 102;
int AUTO_CONNCT_ADDR = 104;
int MAX_TIMERS_ADDR = 106;
int MAX_TEMP_SENSOR_ADDR = 108;
    timeIP = millis();
    lastNTPtime = millis();
    Serial.begin(9600);
    Serial.setRxBufferSize(2048);
    delay(DELAY_MESSAGE_UPDATE);
    SendWiFiLog("WiFi:Init complete..");
    String response = GetPreferenseFromArduino();
    if (response.indexOf(SETTINGS) != -1) {
        SendWiFiLog("WiFi:Load config...");
        if (SetNewPreferenceFromArduino(response)) {
            if (Connection()) {
                indexNTPServer = 0;
                sendNTPpacket();
            SendWiFiLog("WiFi:Error config...");
        SendWiFiLog("Couldn't get config");
        isError = true;
        SendWiFiLog("WiFi:Error...");
byte indexWait = 0;
    if (WIFI_ENABLE && !isError) {
        if (WiFi.status() == WL_CONNECTED) {
            int packetSize = Udp.parsePacket();
            if (packetSize) {
                int len = Udp.read(incomingPacket, MAX_BUFFER);
                if (len > 0) {
                     if (len > MAX_BUFFER) { len = MAX_BUFFER;}
                     incomingPacket[len] = 0;
                isWaitResponse = CheckRequestSimpleCommand(incomingPacket);
                 for (int i = 0; i < MAX_BUFFER; i++) {
                     incomingPacket[i] = 0x0;
                if (!isWaitResponse) {
                    return;
    indexWait = 0;
    while (Serial.available() <= 0 && isWaitResponse) {
        delay(10);
        indexWait++;
        if (indexWait > 100) {
            break;
    indexWait = 0;
    String response = "";
    if (Serial.available() > 0) {
        while (Serial.available()) {
            response += Serial.read();
            delay(1);
        if (response.indexOf(SETTINGS) != -1 && !isSettingsApply) {
            isSettingsApply = true;
                if (Connection())
                    sendNTPpacket();
             Если это не настройки для ESP8266 значит это ответ на запрос от Arduino
             Отправляем его на UDP
            SendResponseSuccess(response);
         Если флаг isWaitResponse все еще активен значит данные не были получены за интервал времени
        if (isWaitResponse) {
            SendResponseError(RESPONSE_NOT_RESPONSE);
    if (millis() > timeIP + DELAY_MESSAGE_UPDATE) {
            SendWifiIp(false, false);
            SendWiFiLog(lastMessage, false);
        timeIP = millis();
    if (millis() > lastNTPtime + DELAY_NTP_UPDATE) {
        indexNTPServer = 0;
        sendNTPpacket();
bool CheckRequestSimpleCommand(String inString) {
    if (inString.indexOf(GET_COMMAND) != -1) {
        SendToSerial(inString, true);
        return true;
    } else if (inString.indexOf(POST_COMMAND) != -1) {
        if (inString.indexOf(F("data")) == -1) {
            SendResponseError(RQUEST_DATA_CORUPTED);
            return false;
        if (inString.indexOf(F("time_NTP")) != -1) {
            SendResponseError(RQUEST_COMPLETE);
            // we don't wait response from arduino when we try set time on device
            return false;
        return true;
    } else if (inString.indexOf(INFO_COMMAND) != -1) {
        // we don't wait response from arduino when we try sent info
        return false;
    return false;
При коротких запросах по типу:
{"status":"get","message":"device"}
{"status":"get","message":"canal_state"}
{"status":"get","message":"timer_daily_state"}
Все работает как часы... Но если попытаться отправить более длинное сообщение к примеру:
{"status":"post","message":"canal_state","data": {"canal":[1,1,1,1,1,1,1,1],"canal_timer":[2,1,1,1,1,1,1,1]}}
Тут же получаю краш модуля и его перезагрузку, после чего он перестает принимать сообщения на UDP порт, нужно передергивать питание.
В логах ошибка:
Exception (3):
epc1=0x401003e9 epc2=0x00000000 epc3=0x00000000 excvaddr=0x400083a1 depc=0x00000000
ctx: sys
sp: 3ffffd40 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffffee0:  ffffffff 3ffee884 3fff18c0 3fffdab0
3ffffef0:  00000000 3fffdad0 3fff083c 00000019
3fffff00:  402169d8 00000000 00000064 401004d8
3fffff10:  3fff0758 0000018f 0000018f 40106c7c
3fffff20:  3fff1f10 3fff1f0c 05d73913 40216859
3fffff30:  3fff1f10 3fff1f0c 05d73913 402169ed
3fffff40:  3ffef7a0 12b087c6 60000600 40216b29
3fffff50:  402169d8 00000000 00000001 4020aef5
3fffff60:  40231164 3ffef778 3ffef7a0 60000600
3fffff70:  12b126ea 3ffef7a0 3ffef778 40231171
3fffff80:  402311b6 3fffdab0 00000000 3fffdcb0
3fffff90:  3ffef7b0 3fffdad0 3fff083c 4020ae8f
3fffffa0:  40000f49 3ffea5a0 3fffdab0 40000f49
<<<stack<<<
Exception 3: LoadStoreError: Processor internal physical address or data error during load or store
Decoding 16 results
0x401003e9: _umm_malloc at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1382
0x402169d8: udp_input at /Users/ivan/e/arduino-esp8266/tools/sdk/lwip/src/core/udp.c line 398
0x401004d8: malloc at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1664
0x40106c7c: pvPortMalloc at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/heap.c line 40
0x40216859: udp_input at /Users/ivan/e/arduino-esp8266/tools/sdk/lwip/src/core/udp.c line 398
0x402169ed: udp_input at /Users/ivan/e/arduino-esp8266/tools/sdk/lwip/src/core/udp.c line 398
0x40216b29: udp_sendto_if at /Users/ivan/e/arduino-esp8266/tools/sdk/lwip/src/core/udp.c line 398
0x4020aef5: BufferDataSource::available() at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\include/DataSource.h line 29
0x40231164: system_adc_read at ?? line ?
0x40231171: system_adc_read at ?? line ?
0x402311b6: system_adc_read_fast at ?? line ?
0x4020ae8f: __exchange_and_add_single at c:\users\doc\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\ext/atomicity.h line 68
: (inlined by) __exchange_and_add_dispatch at c:\users\doc\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\ext/atomicity.h line 86
: (inlined by) std::_Sp_counted_base(__gnu_cxx::_Lock_policy)0>::_M_release() at c:\users\doc\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits/shared_ptr_base.h line 141
: (inlined by) std::__shared_count(__gnu_cxx::_Lock_policy)0>::~__shared_count() at c:\users\doc\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits/shared_ptr_base.h line 546
Даже не знаю куда смотреть? Неужели переполнение буфера UART?
Скорость приема UDP у ESP8266 за 1.8 МБайт в сек. У UART на 9600 всего до 960 байт в сек... WiFi в 2 тысячи раз быстрее :) В UART-TCP используется закрытие окна (TCP стек) приема и передающий ждет... На UDP потерь у WiFi очень много...
DrJarold
Не понимаю. Причем тут скорость UDP? Я слушаю порт UDP:
Далее передаю данные на UART - жду ответа с UART.
Потом передаю ответ на UDP:
void SendResponseSuccess(String message) {
    if (!WIFI_ENABLE || isError)
        return;
    String response = message;
    Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
    char Result[response.length()];
    response.toCharArray(Result, response.length() + 1);
    Udp.write(Result);
    Udp.endPacket();
В чем проблема то? При небольших сообщениях которые < чем буфер UART все работает отлично... Может я просто не понимаю чего-то. Не могли бы вы более развернуто объяснить суть ошибки?
Если сообщение будет > чем буфер UART, куда он его засунет?
А что мешает заняться отладкой? Самый простой способ вывод в важных местах содержания переменных(н.п. размер, наполненность буфера) на UART1.
if (packetSize) {
                              if (len > 0) {
Если условие верно (len больше MAX_BUFFER) , то куда записались данные в Udp.read ?(если размер массива incomingPacket равен MAX_BUFFER ), по логике выполнив int len = Udp.read(incomingPacket, MAX_BUFFER); len всегда должно быть меньше или равно MAX_BUFFER
Если len равна MAX_BUFFER, то incomingPacket[len] = 0; может испортить ваши данные, так как последний элемент массива incomingPacket[MAX_BUFFER-1]
DrJarold
Ну если речь идет о буфере ESP то буфер гораздо больше чем отправляемые сообщения:
А если проблема в буфере Arduino то почему тогда падет ESP?
DrJarold
if (packetSize) {
                              if (len > 0) {
Максимум я отправляю 300 байт, это самое большое сообщение которое можно отправить. Буфер же:
А что вы делаете на "отправителе", если нет ответа (пусть потеря UDP пакетов) ?
Посылаете новый MAX_BUFFER? :)
DrJarold
Отправитель это собственно я, который вручную отправляет пакеты... т.е. вариант когда мы спамим устройство тут не рассматривается.
Т.е. просто маемся дурью для поиграться на сон? :)
Тогда покинем вас - у нас есть игрушки получше... :p
DrJarold
Честно говоря не совсем Вас понял. Я описал проблему, если вы знаете причину, почему прямо не написать? Или вы пытаетесь меня навести на какую-то мысль наводящими вопросами? Ну я тогда пока не уловил сути... Если речь идет о переполнение буфера, то смею вас заверить что краш можно получить первой же отправкой пакета.
В вашем коде нет никаких ограничений ни по каким переполнениям. Так в игрушки не играют. :)
Тем более вам уже посоветовали поставить проверки, а не гадать... Всех условий вашей игры тут никто не знает и играть не смогут :)
А я рассматриваю стандартней случай, типа устройство включено в общую инет сеть и на неё попал поток UDP, пусть какого канала теле-вещания :) Кранты тогда вашей игрушке за долю секунды, пока сервак не прервет поток из-за неответа …
DrJarold
Может кто сталкивался с падением модуля после отправки сообщения по UDP причем падает конкретно, сразу после отправки определенного сообщения. Код выше.
  Serial.println("2");
      Serial.println("3");
    return;
  Serial.println("2_1");
  Serial.println("2_2");
  Serial.println("2_3");
  Serial.println("2_4");
  Udp.write(Result);
  Serial.println("2_5");
  Udp.endPacket();
  Serial.println("2_6");
Для любых сообщений все работает штатно:
{"status":"success","message":"c_s","data":{"cl":[1,1,1,1,1,1,1,1],"c_t":[3,3,3,3,3,3,3,3]}}
2_1
2_2
2_3
2_4
2_5
2_6
3
2
{"status":"success","message":"dev","data":{"ver":"AQ_CH08W","m_t":8,"m_t_se":4,"min_t":1600,"max_t":3500}}
2_1
2_2
2_3
2_4
2_5
2_6
3
Но как только отправляю: {"status":"success","message":"t_sen","data":{"t_se":[0,0,0,0]}}
Сразу получаю краш:
0x4020207d: Print::write(char const*) at ?? line ?
0x4010020c: _umm_free at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1287
0x4010068c: free at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc/umm_malloc.c line 1733
0x4020ab1c: String::String(unsigned long, unsigned char) at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 519
0x40203f14: SendResponseSuccess(String) at ?? line ?
0x4020abf5: String::concat(char const*) at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 519
0x4020acf8: String::concat(__FlashStringHelper const*) at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.cpp line 519
0x40201406: __pinMode at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/core_esp8266_wiring_digital.c line 32
0x4020408a: loop at C:\Users\Doc\Desktop\sketch_jul29a/sketch_jul29a.ino line 207 (discriminator 1)
0x402038de: SendResponseError(String) at C:\Users\Doc\Desktop\sketch_jul29a/sketch_jul29a.ino line 545
0x4020b6d4: WiFiClient::peek() at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.cpp line 151
0x4010070c: cont_norm at C:\Users\Doc\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/cont.S line 109
Если менять порядок отправки сообщений то падает именно на {"status":"success","message":"t_sen","data":{"t_se":[0,0,0,0]}}
Хз почему...
предположу , что конец строки теряется.
Попробуйте собрать ее из более простых участков.
DrJarold
А как это влияет на отправку сообщения UDP? Падает сразу после Serial.println("2_6"); т.е. Serial.println("3"); уже не выполняется.
Знал бы прикуп...
Пока все, что я вижу в Вашем сообщении об ошибке - это ошибка в malloc . Это функция выделения и освобождения памяти. Поэтому можно предположит что ошибка в использовании памяти.
так как Вы указываете что ошибка в конкретной сборке отсылаемой строки, то и ошибку надо искать на основе этой сборки.
Пока все, что могу предположить.
Ищущий да обрящет.
