Ни в коем случае, прошу лишь примеры покидать.Вы хотите, чтобы мы угадали, что делаете нет, не видя кода?
Rui Santos
Complete project details at https://RandomNerdTutorials.com/esp32-websocket-server-arduino/
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
// Import required libraries
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include "DHT.h"
#define DHTPIN 17
DHT dht(DHTPIN, DHT22);
// Replace with your network credentials
const char* ssid = "*****";
const char* password = "*****";
String temperature;
String humidity;
bool ledState = 0;
const int ledPin = 2;
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
AsyncWebSocket ws("/ws");
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<title>ESP Web Server</title>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="icon" href="data:,">
<style>
html {
font-family: Arial, Helvetica, sans-serif;
text-align: center;
h1 {
font-size: 1.8rem;
color: white;
h2{
font-size: 1.5rem;
font-weight: bold;
color: #143642;
.topnav {
overflow: hidden;
background-color: #143642;
body {
margin: 0;
.content {
padding: 30px;
max-width: 600px;
margin: 0 auto;
.card {
background-color: #F8F7F9;;
box-shadow: 2px 2px 12px 1px rgba(140,140,140,.5);
padding-top:10px;
padding-bottom:20px;
.button {
padding: 15px 50px;
font-size: 24px;
text-align: center;
outline: none;
color: #fff;
background-color: #0f8b8d;
border: none;
border-radius: 5px;
-webkit-touch-callout: none;
-webkit-user-select: none;
-khtml-user-select: none;
-moz-user-select: none;
-ms-user-select: none;
user-select: none;
-webkit-tap-highlight-color: rgba(0,0,0,0);
/*.button:hover {background-color: #0f8b8d}*/
.button:active {
box-shadow: 2 2px #CDCDCD;
transform: translateY(2px);
.state {
font-size: 1.5rem;
color:#8c8c8c;
font-weight: bold;
</style>
</head>
<body>
<div class="topnav">
<h1>ESP WebSocket Server</h1>
</div>
<div class="content">
<div class="card">
<h2>Output - GPIO 2</h2>
<p class="state">state: <span id="state">%STATE%</span></p>
<p class="state">temp: <span id="temp">%TEMP%</span></p>
<p><button id="button" class="button">Toggle</button></p>
</div>
</div>
<script>
var gateway = `ws://${window.location.hostname}/ws`;
var websocket;
window.addEventListener('load', onLoad);
function initWebSocket() {
console.log('Trying to open a WebSocket connection...');
websocket = new WebSocket(gateway);
websocket.onopen = onOpen;
websocket.onclose = onClose;
websocket.onmessage = onMessage; // <-- add this line
function onOpen(event) {
console.log('Connection opened');
function onClose(event) {
console.log('Connection closed');
setTimeout(initWebSocket, 2000);
function onMessage(event) {
var state;
if (event.data == "1"){
state = "ON";
else{
state = "OFF";
document.getElementById('state').innerHTML = state;
function onLoad(event) {
initWebSocket();
initButton();
function initButton() {
document.getElementById('button').addEventListener('click', toggle);
function toggle(){
websocket.send('toggle');
</script>
</body>
</html>
)rawliteral";
void notifyClients() {
ws.textAll(String(ledState));
void handleWebSocketMessage(void *arg, uint8_t *data, size_t len) {
AwsFrameInfo *info = (AwsFrameInfo*)arg;
if (info->final && info->index == 0 && info->len == len && info->opcode == WS_TEXT) {
data[len] = 0;
if (strcmp((char*)data, "toggle") == 0) {
ledState = !ledState;
notifyClients();
digitalWrite(ledPin, ledState);
void onEvent(AsyncWebSocket *server, AsyncWebSocketClient *client, AwsEventType type,
switch (type) {
case WS_EVT_CONNECT:
Serial.printf("WebSocket client #%u connected from %s\n", client->id(), client->remoteIP().toString().c_str());
break;
case WS_EVT_DISCONNECT:
Serial.printf("WebSocket client #%u disconnected\n", client->id());
break;
case WS_EVT_DATA:
handleWebSocketMessage(arg, data, len);
break;
case WS_EVT_PONG:
case WS_EVT_ERROR:
break;
void initWebSocket() {
ws.onEvent(onEvent);
server.addHandler(&ws);
String processor(const String& var){
Serial.println(var);
if(var == "STATE"){
if (ledState){
return "ON";
else{
return "OFF";
if(var == "TEMP"){
return String(temperature) ;
return String();
void setup(){
// Serial port for debugging purposes
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
// Connect to Wi-Fi
WiFi.begin(ssid, password);
delay(1000);
Serial.println("Connecting to WiFi..");
// Print ESP Local IP Address
initWebSocket();
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/html", index_html, processor);
// Start server
server.begin();
dht.begin();
ws.cleanupClients();
temperature=String(dht.readTemperature());
humidity=String(dht.readHumidity());
Serial.println(temperature);
Serial.println(humidity);
delay(2000);
Посмотрите что выводится в отладочной консоли браузера, и в Serial порт на ESP32.пытаюсь вывести на страницу примера значения с DTH22 но значения обновляются только с перезагрузкой страницы.
ws.textAll("temperature1=" + String(t));
var arrayS = event.data.split("=");
switch (trim = arrayS[0]) {
case 'temperature1': document.getElementById("temp").innerHTML = arrayS[1]; break
case 'humidity1': document.getElementById("hum").innerHTML = arrayS[1]; break
function Complete()
var Elem = document.Sel1.Message.value;
alert(Elem);
websocket.send('message'+ Elem)
data[len] = 0;
if (strcmp((char*)data, "toggle1") == 0) {ledState1 = !ledState1;notifyClients1();}
if (strcmp((char*)data, "toggle2") == 0) {ledState2 = !ledState2;notifyClients2();}
if (strcmp((char*)data, "toggle3") == 0) {ledState3 = !ledState3;notifyClients3();}
if (strcmp((char*)data, "toggle4") == 0) {ledState4 = !ledState4;notifyClients4();}
if (strcmp((char*)data, "toggle5") == 0) {ledState5 = !ledState5;notifyClients5();}
if (strcmp((char*)data, "toggle6") == 0) {ledState6 = !ledState6;notifyClients6();}
if (strcmp((char*)data, "message") == 0) {Serial.println("OK");}
У меня библиотека другая но общий смысл примерно такой же. Так мой type это похоже ваш info->opcodeта часть кода практически непонятна кроме изменения ledState )) .
void webSocketEvent(byte num, WStype_t type, uint8_t * payload, size_t length){
switch(type)
case WStype_ERROR:
//Serial.printf("info: [%u] WStype_ERROR\n ",num);
break;
case WStype_DISCONNECTED:
//Serial.printf("info: [%u] WStype_DISCONNECTED\n",num);
//Serial.printf("info: [%u] Clients=%u \n",num, webSocket.connectedClients(true));
break;
case WStype_CONNECTED :
//Serial.printf("info: [%u] WStype_CONNECTED\n");
break;
case WStype_BIN :
//Serial.printf("info: [%u] WStype_BIN\n",num);
break;
case WStype_FRAGMENT_TEXT_START :
//Serial.printf("info: [%u] WStype_FRAGMENT_TEXT_START\n",num);
break;
case WStype_FRAGMENT_BIN_START :
//Serial.printf("info: [%u] WStype_FRAGMENT_BIN_START\n",num);
break;
case WStype_FRAGMENT :
//Serial.printf("info: [%u] WStype_FRAGMENT\n",num);
break;
case WStype_FRAGMENT_FIN :
//Serial.printf("info: [%u] WStype_FRAGMENT_FIN\n",num);
break;
case WStype_PING :
//Serial.printf("info: [%u] WStype_PING\n",num);
break;
case WStype_PONG :
//Serial.printf("info: [%u] WStype_PONG\n",num);
break;
case WStype_TEXT:
Serial.printf("info;[%u] WStype_TEXT %s\n",num, payload);
if(length==2)
if((char) payload[0]=='p')
switch((char) payload[1]){
case '0':
sendCode(post0On,post0Off);
webSocket.broadcastTXT("info: ping0");
break;
case '1':
sendCode(post1On,post1Off);
break;
case '2':
sendCode(post2On,post2Off);
break;
case '3':
sendCode(post3On,post3Off);
break;
case '4':
sendCode(post4On,post4Off);
break;
case '5':
sendCode(post5On,post5Off);
break;
case '6':
pingAll();
break;
case '7':
pingOffAll();
break;
break;
#include <Arduino.h>
#include <WebSocketsServer.h> //
#include <ESP8266WebServer.h>
ESP8266WebServer server(80);
WebSocketsServer webSocket(81);
uint32_t loopCounter, maxSendTime, sendTime, sliderValue;
<!DOCTYPE HTML>
<html>
<head>
</head>
<body>
<input id="Slider" type="range" min="0" max="255" value="Slider value: 0" step="1" oninput="sendDats();" />
<p id="Slider_text"></p>
<p class="state">Incoming text: <span id="state">0</span></p>
<p><button id="button" class="button">Reset</button></p>
<script>
let gateway = `ws://${window.location.hostname}:81/`;
let websocket;
setTimeout(initWebSocket, 100);
let state;
state = event.data;
//console.log(JSON.parse(event.data));
document.querySelector("#state").textContent = state;
document.querySelector("#Slider_text").textContent = "Slider value: " + JSON.parse(event.data).sliderValue;
initWebSocket();
document.getElementById('button').addEventListener('click', reset);
function reset() {
websocket.send('reset');
function sendDats() {
let sendValue = parseInt(document.getElementById('Slider').value).toString();
websocket.send(sendValue);
</script>
</body>
</html>
)rawliteral";
void webSocketEvent(uint8_t num, WStype_t type, uint8_t *payload, size_t length)
if (type == WStype_TEXT)
Serial.printf("[%u] get Text: %s\n", num, payload);
sliderValue = atoi((char *)payload);
if (strcmp((char *)payload, "reset") == 0)
maxSendTime = loopCounter = 0;
WiFi.begin("ZyXEL");
yield();
webSocket.begin();
webSocket.onEvent(webSocketEvent);
server.on("/", []()
{ server.send(200, "text/html", index_html); });
server.begin();
delay(10);
webSocket.loop();
server.handleClient();
String sendString = "{\"sendTime\":" + String(sendTime) +
",\"maxSendTime\": " + String(maxSendTime) +
",\"loopCounter\":" + String(loopCounter++) +
",\"sliderValue\":" + String(sliderValue) +
uint32_t startTime = micros();
webSocket.broadcastTXT(sendString);
sendTime = micros() - startTime;
if (sendTime > maxSendTime)
maxSendTime = sendTime;
