Нужна помощь https
Alexey888
Добрый день. Пытаюсь настроить https (arduino ide). Нашел пример скетча httpsrequest, залил, всё работает. Взял хостинг с ssl, щас думаю за минуту скетч подправлю (данные поменяю на свои) и всё. Но увы.. радость была не долгой.. не заработало.
Строки из примера:
*  HTTP over TLS (HTTPS) example sketch
*  This example demonstrates how to use
*  WiFiClientSecure class to access HTTPS API.
*  We fetch and display the status of
*  esp8266/Arduino project continuous integration
*  build.
*  Created by Ivan Grokhotkov, 2015.
*  This example is in public domain.
#include <WiFiClientSecure.h>
const char* ssid = "ss";
const char* password = "pwd";
const char* host = "api.github.com";
const int httpsPort = 443;
// Use web browser to view and copy
// SHA1 fingerprint of the certificate
const char* fingerprint = "CF 05 98 89 CA FF 8E D8 5E 5C E0 C2 E4 F7 E6 C3 C7 50 DD 5C";
  Serial.print("connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  // Use WiFiClientSecure class to create TLS connection
  WiFiClientSecure client;
  Serial.println(host);
  if (!client.connect(host, httpsPort)) {
    return;
  if (client.verify(fingerprint, host)) {
    Serial.println("certificate matches");
  } else {
    Serial.println("certificate doesn't match");
  String url = "/repos/esp8266/Arduino/commits/master/status";
  Serial.print("requesting URL: ");
  Serial.println(url);
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "User-Agent: BuildFailureDetectorESP8266\r\n" +
               "Connection: close\r\n\r\n");
  Serial.println("request sent");
  while (client.connected()) {
    String line = client.readStringUntil('\n');
    if (line == "\r") {
      Serial.println("headers received");
      break;
  if (line.startsWith("{\"state\":\"success\"")) {
    Serial.println("esp8266/Arduino CI successfull!");
  } else {
    Serial.println("esp8266/Arduino CI has failed");
  Serial.println("reply was:");
  Serial.println("==========");
  Serial.println(line);
  Serial.println("closing connection");
Для тестов, меняю на яндекс:
*  build.
const char* host = "yandex.ru";
const char* fingerprint = "‎8f 16 94 46 f3 6b 83 4d 39 39 52 a9 ef 7f 31 4b bd 1b f6 49";
    delay(500);
    Serial.print(".");
  Serial.println("");
    return;
  } else {
  String url = "/repos/esp8266/Arduino/commits/master/status"; // это мне пока не важно, проблема выше
    if (line == "\r") {
      break;
  } else {
В результате получаю ответ:
connecting to yandex.ru
В чем беда? мб кто работал с https
Alexey888
Чутка разобрался, вот тестовый код с данными:
const char* ssid = "pp";
//const char* host = "github.com";
//const char* host = "google.ru";
//const char* host = "yandex.ru";
//const char* host = "mail.ru";
//const char* host = "alfabank.ru";
//const char* host = "ozon.ru";
const char* host = "vk.com";
//const char* fingerprint = "d7 9f 07 61 10 b3 92 93 e3 49 ac 89 84 5b 03 80 c1 9e 2f 8b"; //github.com
//const char* fingerprint = "da bd 42 db 58 2e 1d e6 3e 4f 08 65 8d 90 ec 46 48 06 ae 1f"; //google.ru
//const char* fingerprint = "8f 16 94 46 f3 6b 83 4d 39 39 52 a9 ef 7f 31 4b bd 1b f6 49"; //yandex.ru
//const char* fingerprint = "68 2c 40 44 35 17 41 55 76 a2 94 9d 48 6d 95 1c d8 6d 28 88"; //mail.ru
//const char* fingerprint = "a3 9a 27 a1 59 6c 72 2d 50 b5 ab 59 21 8e 3b 2a bb 7c b2 b5"; //alfabank.ru
//const char* fingerprint = "e7 e7 6f 15 6e 43 a5 1b 9a ed 6c d5 04 fe ed 23 c0 80 4f 05"; //ozon.ru
const char* fingerprint = "fb 9b af 57 f4 46 7c bf 90 80 e5 7a 18 6e 15 a3 0f 11 dd 9f"; //vk.com
    delay(500);
    Serial.print(".");
  Serial.println("");
  else
    Serial.println("OK");
    } else {
  delay(5000);
В итоге получились такие результаты:
WiFi connected
IP address:
192.168.1.146
connecting to github.com
OK
certificate matches
OK
certificate matches
OK
certificate matches
WiFi connected
IP address:
192.168.1.146
connecting to google.ru
// зависает при конекте, пробовал несколько раз
PORT CLOSED
WiFi connected
IP address:
192.168.1.146
OK
OK
OK
WiFi connected
IP address:
192.168.1.146
connecting to mail.ru
OK
certificate matches
OK
certificate matches
OK
certificate matches
OK
certificate matches
WiFi connected
IP address:
192.168.1.146
connecting to alfabank.ru
OK
certificate matches
OK
certificate matches
OK
certificate matches
OK
certificate matches
WiFi connected
IP address:
192.168.1.146
connecting to ozon.ru
OK
certificate matches
OK
certificate matches
OK
certificate matches
WiFi connected
IP address:
192.168.1.146
connecting to vk.com
connection failed
connection failed
connection failed
К некоторых случаях всё проходит на ура, в некоторых не чекает сертификат, ну и в худшем совсем не идет конект.
Вопрос, от чего такая картина? что за бред...
Надеюсь кто-нибудь поможет и внесет ясность. Спасибо.
ave
А кто подскажет где берутся эти цифры? Я так понял это сертификаты.
//const char* fingerprint = "fb 9b af 57 f4 46 7c bf 90 80 e5 7a 18 6e 15 a3 0f 11 dd 9f"; //vk.com
По этому примеру у меня выдает:
Connecting to: mail.ru
Connection Ok
Certificate Error
ave
Сам разобрался. Эти цифры - это отпечаток сертификата, беруться из браузера на сайте.
Сам разобрался. Эти цифры - это отпечаток сертификата, берутся из браузера на сайте.
Т.е. если обращаться на другой сайт HTTPS надо искать эти "отпечатки"?
Почему нельзя без этого:
#include <WiFi.h>
//char ssid[] = "yourNetwork"; //  your network SSID (name)
//char pass[] = "secretPassword";    // your network password (use for WPA, or use as key for WEP)
#include <myAP.h> // там прописаны pass и ssid и #define password pass для быстрой замены в разных примерах...
int keyIndex = 0;            // your network key Index number (needed only for WEP)
char server[] = "yandex.ru"; // "esp8266.ru"; // "github.com"; // "esp8266.ru";//  "yandex.ru"; //"www.google.com"; // "github.com";// name address for Google (using DNS)
//unsigned char test_client_key[] = "";   //For the usage of verifying client
//unsigned char test_client_cert[] = "";  //For the usage of verifying client
//unsigned char test_ca_cert[] = "";      //For the usage of verifying server
WiFiSSLClient client;
extern "C" void sys_info(void);
  // Connect to WPA/WPA2 network.
  while (WiFi.begin(ssid,pass) != WL_CONNECTED) {
    // wait 0.1 seconds for connection:
    delay(100);
  Serial.println("Connected to wifi");
  if (client.connect(server, 443)) { //client.connect(server, 443, test_ca_cert, test_client_cert, test_client_key)
    Serial.println("connected to server");
    // Make a HTTP request:
    client.println("GET / HTTP/1.1"); // client.println("GET /search?q=realtek HTTP/1.0");
    client.print("Host: "); client.println(server); //    client.println("Host: www.google.com");
    client.println("Connection: close");
    client.println();
  else
  Serial.println("connected to server failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  while (client.available()) {
    char c = client.read();
    Serial.write(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting from server.");
    client.stop();
    sys_info();
    Serial.println("End.");
    // do nothing forevermore:
    while (true);
===== Enter Image 1.5 ====
Img2 Sign: RTKWin, InfaStart @ 0x1000604d
===== Enter Image 2 ====
CLK CPU         166666666 Hz
RAM heap        81504 bytes
TCM heap        64768 bytes
interface 0 is initialized
interface 1 is initialized
Initializing WIFI ...
WIFI initialized
RTL8195A[Driver]: set ssid [********]
RTL8195A[Driver]: start auth to **:**:**:**:**:**
RTL8195A[Driver]: auth success, start assoc
RTL8195A[Driver]: association success(res=3)
RTL8195A[Driver]: set pairwise key to hw: alg:4(WEP40-1 WEP104-5 TKIP-2 AES-4)
RTL8195A[Driver]: set group key to hw: alg:4(WEP40-1 WEP104-5 TKIP-2 AES-4) keyid:1
Interface 0 IP address : 192.168.1.122Connected to wifi
connected to server
HTTP/1.1 200 Ok
Date: Thu, 17 Nov 2016 16:37:00 GMT
Content-Type: text/html; charset=UTF-8
<!--n7.wfront.yandex.net--></body></html>
RAM heap        50096 bytes
TCM heap        27928 bytes
End.
  • Like
Реакции: ave
Алексей.
Что такое продление сертификата?
Это выпуск нового с прежним ключом и новым сроком годности?
Технически это возможно, но практически не встречал. Отпечаток всё равно должен быть другим.
Belerafon
Изменился после продления сертификата Let's Encrypt он на 3 месяца дается. т.е. все эти отпечатки фигня получается. Соответственная старая прошивка больше не получит доступ к серверу. Как обойти этот отпечаток?
