Как подключить ESP 12 к роутеру через WPS?
Avikmen
Есть плата NodeMCU 1.0 . Программирую через Arduino IDE. И вот задача. Подключиться к роутеру, который находится в режиме WPS. Как заставить esp подружится с роутером без пароля?
tretyakov_sa
Попробуй так:
// Test for ESP8266 WPS connection.
  // WPS works in STA (Station mode) only.
  WiFi.mode(WIFI_STA);
  delay(1000);
  // Called to check if SSID and password has already been stored by previous WPS call.
  // The SSID and password are stored in flash memory and will survive a full power cycle.
  // Calling ("",""), i.e. with blank string parameters, appears to use these stored values.
  WiFi.begin("","");
  // Long delay required especially soon after power on.
  delay(4000);
  // Check if WiFi is already connected and if not, begin the WPS process.
  if (WiFi.status() != WL_CONNECTED) {
      Serial.println("\nAttempting connection ...");
      WiFi.beginWPSConfig();
      // Another long delay required.
      delay(3000);
      if (WiFi.status() == WL_CONNECTED) {
        Serial.println("Connected!");
        Serial.println(WiFi.SSID());
        Serial.println(WiFi.macAddress());
      else {
        Serial.println("Connection failed!");
  else {
    Serial.println("\nConnection already established.");
Пишите на СИ и используйте UDK.
далее документация SDK_programmingGuide стр 77
