Компиляция UDK под linux
tonal
Попробовал скомпилить под Linux (Kubuntu 14.04)
Для этого чуток подправил build-xtensa-lx106-elf.sh - добавил параметр отключающий mingw
Получаю ошибку компиляции:
/home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/./gcc/xgcc -shared-libgcc -B/home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/./gcc -nostdinc++ -L/home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/src -L/home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/src/.libs -L/home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/libsupc++/.libs -B/home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/xtensa-lx106-elf/xtensa-lx106-elf/bin/ -B/home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/xtensa-lx106-elf/xtensa-lx106-elf/lib/ -isystem /home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/xtensa-lx106-elf/xtensa-lx106-elf/include -isystem /home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/xtensa-lx106-elf/xtensa-lx106-elf/sys-include    -x c++-header -nostdinc++ -g -O2  -I/home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/include/xtensa-lx106-elf -I/home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/include -I/home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/libstdc++-v3/libsupc++ -O2 -g -std=gnu++0x /home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/libstdc++-v3/include/precompiled/stdc++.h \
        -o xtensa-lx106-elf/bits/stdc++.h.gch/O2ggnu++0x.gch
In file included from /home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/include/bits/char_traits.h:380:0,
                 from /home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/include/ios:40,
                 from /home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/include/istream:38,
                 from /home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/include/sstream:38,
                 from /home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/include/complex:45,
                 from /home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/include/ccomplex:38,
                 from /home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/libstdc++-v3/include/precompiled/stdc++.h:52:
/home/tonal/lang/work/esp8266/esp8266-devkit/Espressif/dl/gcc-xtensa/build-2/xtensa-lx106-elf/libstdc++-v3/include/cstdint:78:11: error: 'uint_least32_t' is already declared in this scope
   using ::uint_least32_t;
Это как-нибудь лечится?
tonal
Скорее от непонимания чем они отличаются. :)
Не можете кратко набросать?
CHERTS
esp-open-sdk позволяет собрать компилятор значительно проще, чем если Вы будите использовать скрипт build-xtensa-lx106-elf.sh + там сразу идет esptool + Espressif SDK, то есть получается полный комплект для разработки.
build-xtensa-lx106-elf.sh соберет только компилятор.
