WriteMultipleVoltages
Reads analog voltages from pins 0-7 and writes them to the 8 fields of a channel on ThingSpeak every 20 seconds.
ThingSpeak ( https://www.thingspeak.com ) is a free IoT service for prototyping
systems that collect, analyze, and react to their environments.
Copyright 2015, The MathWorks, Inc.
Documentation for the ThingSpeak Communication Library for Arduino is in the extras/documentation folder where the library was installed.
See the accompaning licence file for licensing information.
#ifdef SPARK
#include "ThingSpeak/ThingSpeak.h"
#else
#include "ThingSpeak.h"
#endif
// This example selects the correct library to use based on the board selected under the Tools menu in the IDE.
// Yun, Wired Ethernet shield, wi-fi shield, esp8266, and Spark are all supported.
// With Uno and Mega, the default is that you're using a wired ethernet shield (http://www.arduino.cc/en/Main/ArduinoEthernetShield)
// If you're using a wi-fi shield (http://www.arduino.cc/en/Main/ArduinoWiFiShield), uncomment the line below
//#define USE_WIFI_SHIELD
#ifdef ARDUINO_ARCH_AVR
#ifdef ARDUINO_AVR_YUN
#include "YunClient.h"
YunClient client;
#else
#ifdef USE_WIFI_SHIELD
#include <SPI.h>
// ESP8266 USERS -- YOU MUST COMMENT OUT THE LINE BELOW. There's a bug in the Arduino IDE that causes it to not respect #ifdef when it comes to #includes
// If you get "multiple definition of `WiFi'" -- comment out the line below.
#include <WiFi.h>
char ssid[] = "<YOURNETWORK>"; // your network SSID (name)
char pass[] = "<YOURPASSWORD>"; // your network password
int status = WL_IDLE_STATUS;
WiFiClient client;
#else
// Use wired ethernet shield
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
EthernetClient client;
#endif
#endif
// On Arduino: 0 - 1023 maps to 0 - 5 volts
#define VOLTAGE_MAX 5.0
#define VOLTAGE_MAXCOUNTS 1023.0
#endif
#ifdef ARDUINO_ARCH_ESP8266
WiFiClient client;
// On ESP8266: 0 - 1023 maps to 0 - 1 volts
#define VOLTAGE_MAX 1.0
#endif
#ifdef SPARK
TCPClient client;
#define VOLTAGE_MAX 3.3
#define VOLTAGE_MAXCOUNTS 4095.0
#endif
**** Visit https://www.thingspeak.com to sign up for a free account and create
**** a channel. The video tutorial http://community.thingspeak.com/tutorials/thingspeak-channels/
**** has more information. You need to change this to your channel, and your write API key
**** IF YOU SHARE YOUR CODE WITH OTHERS, MAKE SURE YOU REMOVE YOUR WRITE API KEY!!
unsigned long myChannelNumber = 31461;
const char * myWriteAPIKey = "LD79EOAAWRVYF04Y";
#if defined(ARDUINO_ARCH_AVR) || defined(ARDUINO_ARCH_ESP8266)
Bridge.begin();
#else
#if defined(USE_WIFI_SHIELD) || defined(ARDUINO_ARCH_ESP8266)
WiFi.begin(ssid, pass);
#else
Ethernet.begin(mac);
#endif
#endif
#endif
ThingSpeak.begin(client);
// Read the input on each pin, convert the reading, and set each field to be sent to ThingSpeak.
// On Particle: 0 - 4095 maps to 0 - 3.3 volts
float pinVoltage = analogRead(A0) * (VOLTAGE_MAX / VOLTAGE_MAXCOUNTS);
ThingSpeak.setField(1,333);
#ifndef ARDUINO_ARCH_ESP8266
// The ESP8266 only has one analog input, so skip this
pinVoltage = analogRead(A1) * (VOLTAGE_MAX / VOLTAGE_MAXCOUNTS);
ThingSpeak.setField(2,pinVoltage);
pinVoltage = analogRead(A2) * (VOLTAGE_MAX / VOLTAGE_MAXCOUNTS);
ThingSpeak.setField(3,pinVoltage);
pinVoltage = analogRead(A3) * (VOLTAGE_MAX / VOLTAGE_MAXCOUNTS);
ThingSpeak.setField(4,pinVoltage);
pinVoltage = analogRead(A4) * (VOLTAGE_MAX / VOLTAGE_MAXCOUNTS);
ThingSpeak.setField(5,pinVoltage);
pinVoltage = analogRead(A5) * (VOLTAGE_MAX / VOLTAGE_MAXCOUNTS);
ThingSpeak.setField(6,pinVoltage);
pinVoltage = analogRead(A6) * (VOLTAGE_MAX / VOLTAGE_MAXCOUNTS);
ThingSpeak.setField(7,pinVoltage);
pinVoltage = analogRead(A7) * (VOLTAGE_MAX / VOLTAGE_MAXCOUNTS);
ThingSpeak.setField(8,pinVoltage);
#endif
// Write the fields that you've set all at once.
ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
delay(20000); // ThingSpeak will only accept updates every 15 seconds.
