NodeMCU Robot Car
Volt-Amper
#define ENA   14          // Enable/speed motors Right        GPIO14(D5)
#define ENB   12          // Enable/speed motors Left         GPIO12(D6)
#define IN_1  15          // L298N in1 motors Right           GPIO15(D8)
#define IN_2  13          // L298N in2 motors Right           GPIO13(D7)
#define IN_3  2           // L298N in3 motors Left            GPIO2(D4)
#define IN_4  0           // L298N in4 motors Left            GPIO0(D3)
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
String command;             //String to store app command state.
int speedCar = 800;         // 400 - 1023.
int speed_Coeff = 3;
const char *ssid = "Smart Car";
const char *password = "12345678";
ESP8266WebServer server(80);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
pinMode(IN_1, OUTPUT);
pinMode(IN_2, OUTPUT);
pinMode(IN_3, OUTPUT);
pinMode(IN_4, OUTPUT);
// Connecting WiFi
Serial.println(ssid);
WiFi.mode(WIFI_STA); // Задаем режим работы WIFI_STA (клиент)
WiFi.begin(ssid, password); // Подключаемся
while (WiFi.status() != WL_CONNECTED) // Ждем пока статус не станет WL_CONNECTED
delay(500);
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); // показывает наше IP
// Starting WEB-server
     server.on ( "/", HTTP_handleRoot );
     server.onNotFound ( HTTP_handleRoot );
     server.begin();
void goAhead(){
      digitalWrite(IN_1, LOW);
      digitalWrite(IN_2, HIGH);
      analogWrite(ENA, speedCar);
      digitalWrite(IN_3, LOW);
      digitalWrite(IN_4, HIGH);
      analogWrite(ENB, speedCar);
void goBack(){
      digitalWrite(IN_1, HIGH);
      digitalWrite(IN_2, LOW);
      digitalWrite(IN_3, HIGH);
      digitalWrite(IN_4, LOW);
void goRight(){
void goLeft(){
void goAheadRight(){
      analogWrite(ENA, speedCar/speed_Coeff);
void goAheadLeft(){
      analogWrite(ENB, speedCar/speed_Coeff);
void goBackRight(){
void goBackLeft(){
void stopRobot(){
    server.handleClient();
      command = server.arg("State");
      if (command == "F") goAhead();
      else if (command == "B") goBack();
      else if (command == "L") goLeft();
      else if (command == "R") goRight();
      else if (command == "I") goAheadRight();
      else if (command == "G") goAheadLeft();
      else if (command == "J") goBackRight();
      else if (command == "H") goBackLeft();
      else if (command == "0") speedCar = 400;
      else if (command == "1") speedCar = 470;
      else if (command == "2") speedCar = 540;
      else if (command == "3") speedCar = 610;
      else if (command == "4") speedCar = 680;
      else if (command == "5") speedCar = 750;
      else if (command == "6") speedCar = 820;
      else if (command == "7") speedCar = 890;
      else if (command == "8") speedCar = 960;
      else if (command == "9") speedCar = 1023;
      else if (command == "S") stopRobot();
void HTTP_handleRoot(void) {
if( server.hasArg("State") ){
       Serial.println(server.arg("State"));
  server.send ( 200, "text/html", "" );
  delay(1);
Здравствуйте, возникла проблема в подключении NodeMCU к Wi fi домашней сети. Роутер не находит NodeMCU в списке доступных устройств.
Попробуйте(на роутере и в есп) задать название сети без пробелов.
tretyakov_sa
У меня ваш код прекрасно подключается. Смотрите настройки роутера и сети.
Volt-Amper
Не пойму, если например из Arduino IDE взять пример подключения к WiFi для NodeMCU, то нормально подключается устройство к WiFi-сети, а если задать какие-то функции для подключения периферии(в данном случае это 4 колеса и L298n). В моем коде сверху для подключения NodeMcu к WiFi использовал код из примера Arduino IDE.
Volt-Amper
Вот так подключается NodeMCU к сети с помощью кода в примере, а с кодом выше не хочет подключатся.
поставьте проверку соединения и если есть соединение то работу с GPIO
Volt-Amper
Настройка роутера не причем, другие то устройства подключаюся к wi fi сети, и отдельно если взять пример из Arduino IDE то к сети нормально подключается
ДА я понял вас, но дело в подключении библиотек esp8266WebServer и WifiClient.
поставьте условие проверки подключения и по этому условию вызывайте эти функции
иначе у вас обращение к функциям может блокировать процесс подключения или мешать ему.
Volt-Amper
А вот это не условие проверки соединения:
// Connecting WiFi
delay(500);
     server.begin();
// Connecting WiFi
delay(500);
     server.begin();
покажите картинку терминала что пишет ESP
я не полностью посмотрел сначала ваш скетч
вопрос: вы его сами писали или методом рекле слепили или взяли готовый?
Volt-Amper
Это уже готовый был скетч в интернете. Извиняюсь за качество фото, просто с принскрином это бы заняло минут 10. В терминале он ничего не пишет, хотя если убрать полностью строчки из кода с подключением любой периферии, в данном случае пока это моторы 4WD, то программа работает исправно и в монитор порта выводится, если задаётся например функция WiFiScan из примеров Arduino IDE. И нормально конектится к WiFi, но только если я задаю в поле ssid и password имя и пароль wifi сети, а не то что я создал новое устройство в списке доступных WiFi подключений.
Да вот в том то и дело, по пробывал через Web-сервер http тоже самое.
веб сервер не причем
эти сообщения у вас в самом начале и не зависят от wifi
возможно вы что-то не то грузите в ESP
попробуйте оставить лишь соединение по wifi
и поставьте после каждого оператора печать номера оператора
Volt-Amper
что-то не видно эти сообщения:
  1. Serial.print("Connecting to ");
  2. Serial.println(ssid);
Дело в том что я так уже пробывал и все подключается, но вот этот когда кусок кода вместе с подключением колёс машинки все перестаёт работать. Я вот не пойму, нужно соединение создавать?
