Ошибка парсера JSON
Motobiker
Вот код целиком
struct Config
    String str;
    int val;
    int val1;
    int val2;
    int val3;
    int val4;
    int val5;
    int val6;
    int val7;
    int val8;
    int val9;
    int val10;
  const char *filename = "/config.txt";
  Config config;
  config.str = "stroka";
  config.val = 999;
  config.val1 = 999;
  config.val2 = 999;
  config.val3 = 999;
  config.val4 = 999;
  config.val5 = 999;
  config.val6 = 999;
  config.val7 = 999;
  config.val8 = 999;
  config.val9 = 999;
  File test_file = LittleFS.open(filename, "w+");
  DynamicJsonDocument json_doc(2048);
  json_doc["str"] = "11new stroka";
  json_doc["val"] = 17771;
  json_doc["val1"] = 17771;
  json_doc["val2"] = 17771;
  json_doc["val3"] = 1777;
   json_doc["val4"] = 1777;
  json_doc["val5"] = 1777;
  json_doc["val6"] = 1777;
  json_doc["val7"] = 1777;
  json_doc["val8"] = 1777;
  json_doc["val9"] = 1777;
  json_doc["val10"] = 1777;
  if (serializeJson(json_doc, test_file) == 0)
    Serial.println(F("Failed to write to file"));
  json_doc.clear();
  test_file.close();
  test_file = LittleFS.open(filename, "r");
  DeserializationError error = deserializeJson(json_doc, test_file);
  if (error)
    Serial.println(F("Failed to read file, using default configuration"));
  Serial.println(error.c_str());
  config.str = json_doc["str"].as<String>();
  config.val = json_doc["val"];
  config.val1 = json_doc["val1"];
  config.val2 = json_doc["val2"];
  config.val3 = json_doc["val3"];
  config.val4 = json_doc["val4"];
  config.val5 = json_doc["val5"];
  config.val6 = json_doc["val6"];
  config.val7 = json_doc["val7"];
  config.val8 = json_doc["val8"];
  config.val9 = json_doc["val9"];
  config.val10 = json_doc["val10"];
  test_file.close();
  json_doc.clear();
  Serial.println(config.str);
  Serial.println(config.val);
  Serial.println(config.val1);
  Serial.println(config.val2);
  Serial.println(config.val3);
 Serial.println(config.val4);
  Serial.println(config.val5);
  Serial.println(config.val6);
  Serial.println(config.val7);
  Serial.println(config.val8);
  Serial.println(config.val9);
  Serial.println(config.val10);
И что мне самому смотреть, что она выводит в терминал?
Главный вопрос почему, для чего разное количество?
Займитесь отладкой, для начала вывод сериял, в строку.
Motobiker
сокращаю до 4 параметров и вот
struct Config
    String str;
    int val;
    int val1;
    int val2;
  Config config;
  config.val = 999;
  config.val1 = 999;
  config.val2 = 999;
  json_doc.clear();
  test_file.close();
  if (error)
  test_file.close();
  json_doc.clear();
терминал:
Ok
11new stroka
17771
17771
17771
Motobiker
Методом тыка (постепенно увеличивал размер первого параметра) установил, что файл не может получиться больше 64 байт
Size of test_file is 64
{"str":"new stroka -----","val":17771,"val1":17771,"val2":17771}
Ok
new stroka -----
17771
17771
17771
0
0
0
0
0
0
0
0
Motobiker
ура, победа!
помогла смена параметров чипа в VSCode, в файле platformio.ini
Полгода программировал без проблем, а тут...
Видимо распределение памяти было неверное и под FS осталось 64 байта
