ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode
IO, clock div:2
load:0x3fff0030,len:7172
load:0x40078000,len:15556
load:0x40080400,len:4
0x40080400: _init at ??:?
ho 8 tail 4 room 4
load:0x40080404,len:3904
entry 0x40080640
I (30) boot: ESP-IDF v5.3-dev-1922-g5454d37d49 2nd stage bootloader
I (30) boot: compile time Feb 28 2024 21:18:27
I (32) boot: Multicore bootloader
I (36) boot: chip revision: v1.1
I (40) boot.esp32: SPI Speed : 40MHz
I (45) boot.esp32: SPI Mode : DIO
I (49) boot.esp32: SPI Flash Size : 4MB
I (54) boot: Enabling RNG early entropy source...
I (59) boot: Partition Table:
I (63) boot: ## Label Usage Type ST Offset Length
I (70) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (78) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (85) boot: 2 factory factory app 00 00 00010000 00100000
I (93) boot: End of partition table
I (97) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=21244h (135748) map
I (152) esp_image: segment 1: paddr=0003126c vaddr=3ffb0000 size=04024h ( 16420) load
I (158) esp_image: segment 2: paddr=00035298 vaddr=40080000 size=0ad80h ( 44416) load
I (176) esp_image: segment 3: paddr=00040020 vaddr=400d0020 size=70de0h (462304) map
I (334) esp_image: segment 4: paddr=000b0e08 vaddr=4008ad80 size=0c740h ( 51008) load
I (366) boot: Loaded app from partition at offset 0x10000
I (366) boot: Disabling RNG early entropy source...
I (378) cpu_start: Multicore app
I (387) cpu_start: Pro cpu start user code
I (387) cpu_start: cpu freq: 160000000 Hz
I (387) cpu_start: Application information:
I (390) cpu_start: Project name: eth2ap
I (395) cpu_start: App version: 1
I (399) cpu_start: Compile time: Feb 28 2024 21:18:21
I (405) cpu_start: ELF file SHA256: bb4f60c7d...
I (410) cpu_start: ESP-IDF: v5.3-dev-1922-g5454d37d49
I (417) cpu_start: Min chip rev: v0.0
I (422) cpu_start: Max chip rev: v3.99
I (427) cpu_start: Chip rev: v1.1
I (432) heap_init: Initializing. RAM available for dynamic allocation:
I (439) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (445) heap_init: At 3FFB7768 len 00028898 (162 KiB): DRAM
I (451) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (457) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (464) heap_init: At 400974C0 len 00008B40 (34 KiB): IRAM
I (471) spi_flash: detected chip: generic
I (474) spi_flash: flash io: dio
I (479) main_task: Started on CPU0
I (489) main_task: Calling app_main()
I (519) wifi:wifi driver task: 3ffbeb20, prio:23, stack:6656, core=0
I (519) wifi:wifi firmware version: 550bce5
I (519) wifi:wifi certification version: v7.0
I (519) wifi:config NVS flash: enabled
I (519) wifi:config nano formating: disabled
I (529) wifi:Init data frame dynamic rx buffer num: 32
I (529) wifi:Init static rx mgmt buffer num: 5
I (539) wifi:Init management short buffer num: 32
I (539) wifi:Init dynamic tx buffer num: 32
I (539) wifi:Init static rx buffer size: 1600
I (549) wifi:Init static rx buffer num: 10
I (549) wifi:Init dynamic rx buffer num: 32
I (559) wifi_init: rx ba win: 6
I (559) wifi_init: accept mbox: 6
I (559) wifi_init: tcpip mbox: 32
I (569) wifi_init: udp mbox: 6
I (569) wifi_init: tcp mbox: 6
I (569) wifi_init: tcp tx win: 5760
I (579) wifi_init: tcp rx win: 5760
I (579) wifi_init: tcp mss: 1440
I (589) wifi_init: WiFi IRAM OP enabled
I (589) wifi_init: WiFi RX IRAM OP enabled
I (2469) eth2ap_example: Ethernet Started
I (2469) eth2ap_example: Ethernet Link Up
I (2469) phy_init: phy_version 4791,2c4672b,Dec 20 2023,16:06:06
I (2469) main_task: Returned from app_main()
I (2549) wifi:mode : softAP (b0:a7:32:08:1f:97)
I (2549) wifi:Total power save buffer number: 16
I (2549) wifi:Init max length of beacon: 752/752
I (52399) wifi:new:<1,1>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
I (52399) wifi:station: bc:f4:d4:4f:25:cf join, AID=1, bgn, 40U
I (52459) eth2ap_example: Wi-Fi AP got a station connected
I (52609) wifi:<ba-add>idx:2 (ifx:1, bc:f4:d4:4f:25:cf), tid:0, ssn:1, winSize:64
I (97809) wifi:station: bc:f4:d4:4f:25:cf leave, AID = 1, bss_flags is 658531, bss:0x3ffb8b1c
I (97809) wifi:new:<1,0>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
I (97809) wifi:<ba-del>idx:2, tid:0
I (97819) eth2ap_example: Wi-Fi AP got a station disconnected
I (108299) wifi:new:<1,1>, old:<1,0>, ap:<1,1>, sta:<255,255>, prof:1
I (108299) wifi:station: bc:f4:d4:4f:25:cf join, AID=1, bgn, 40U
I (108349) eth2ap_example: Wi-Fi AP got a station connected
I (108409) wifi:<ba-add>idx:2 (ifx:1, bc:f4:d4:4f:25:cf), tid:0, ssn:1, winSize:64
I (153799) wifi:station: bc:f4:d4:4f:25:cf leave, AID = 1, bss_flags is 658531, bss:0x3ffb8b1c
I (153799) wifi:new:<1,0>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
I (153809) wifi:<ba-del>idx:2, tid:0
I (153809) eth2ap_example: Wi-Fi AP got a station disconnected
I (220469) eth2ap_example: Ethernet Link Down
E (220479) wifi:NAN WiFi stop
I (220479) wifi:flush txq
I (220479) wifi:stop sw txq
I (220479) wifi:lmac stop hw txq
I (230469) eth2ap_example: Ethernet Link Up
I (230479) wifi:mode : softAP (b0:a7:32:08:1f:97)
I (230479) wifi:Total power save buffer number: 16
I (230479) wifi:Init max length of beacon: 752/752
I (232469) eth2ap_example: Ethernet Link Down
E (232479) wifi:NAN WiFi stop
I (232479) wifi:flush txq
I (232479) wifi:stop sw txq
I (232479) wifi:lmac stop hw txq
I (234469) eth2ap_example: Ethernet Link Up
I (234479) wifi:mode : softAP (b0:a7:32:08:1f:97)
I (234479) wifi:Total power save buffer number: 16
I (234479) wifi:Init max length of beacon: 752/752
I (253389) wifi:new:<1,1>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
I (253389) wifi:station: bc:f4:d4:4f:25:cf join, AID=1, bgn, 40U
I (253439) eth2ap_example: Wi-Fi AP got a station connected
I (253599) wifi:<ba-add>idx:2 (ifx:1, bc:f4:d4:4f:25:cf), tid:0, ssn:1, winSize:64
I (298789) wifi:station: bc:f4:d4:4f:25:cf leave, AID = 1, bss_flags is 658531, bss:0x3ffb93d8
I (298789) wifi:new:<1,0>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
I (298799) wifi:<ba-del>idx:2, tid:0
I (298799) eth2ap_example: Wi-Fi AP got a station disconnected
I (370469) eth2ap_example: Ethernet Link Down
E (370479) wifi:NAN WiFi stop
I (370479) wifi:flush txq
I (370479) wifi:stop sw txq
I (370479) wifi:lmac stop hw txq
I (372469) eth2ap_example: Ethernet Link Up
I (372479) wifi:mode : softAP (b0:a7:32:08:1f:97)
I (372479) wifi:Total power save buffer number: 16
I (372479) wifi:Init max length of beacon: 752/752
I (470469) eth2ap_example: Ethernet Link Down
