shavrin777
так, у меня код по прежнему не компилируется попробуй ты
нужна библиотека PubSubClient.h : эскиз -> incude libary -> manage lib -> в поиске PubSubClient
#include "ESP8266MQTTClient.h"
#include <PubSubClient.h>
//#include <WebPage.h>
const char* mqtt_server = "iot.eclipse.org";
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
const char* ssid = "";
const char* password = "";
float var1 = 1;
float var2 = 123;
float var3 = 3;
String WebPage = "<html lang='ru'> <head> <meta charset='utf-8'> <script src='https://cdnjs.cloudflare.com/ajax/libs/paho-mqtt/1.0.1/mqttws31.js' type='text/javascript'></script> <script> var year; var mon; var wday; var day; var hour; var min; var sec; </script> <script> // Create a client instance client = new Paho.MQTT.Client('iot.eclipse.org', Number(80), '/ws','syhtrrt'); // set callback handlers client.onConnectionLost = onConnectionLost; client.onMessageArrived = onMessageArrived; // connect the client client.connect({onSuccess:onConnect}); // called when the client connects function onConnect() { // Once a connection has been made, make a subscription and send a message. console.log('onConnect'); client.subscribe('NOTHING/var1'); client.subscribe('NOTHING/var2'); client.subscribe('NOTHING/var3'); } // called when the client loses its connection function onConnectionLost(responseObject) { if (responseObject.errorCode !== 0) { console.log('onConnectionLost:'+responseObject.errorMessage); } client.connect({onSuccess:onConnect}); } // called when a message arrives function onMessageArrived(message) { if(message.destinationName == 'NOTHING/var1') {var1 = message.payloadString} if(message.destinationName == 'NOTHING/var2') {var2 = message.payloadString} if(message.destinationName == 'NOTHING/var3') {var3 = message.payloadString} document.getElementById('var1').innerText=wday; document.getElementById('var2').innerText=mon; document.getElementById('var3').innerText=year; console.log('onMessageArrived: '+message.payloadString+' '+message.destinationName); } </script> </head> <body> <div class='time'>1=<span id='var1'></span>:2=<span id='var2'></span>:3=<span id='var3'></span></div> "
ESP8266WebServer server(80);
WiFi.begin(ssid, password);
Serial.println("");
delay(500);
Serial.print(".");
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
server.on("/", [](){
server.send(200, "text/html", WebPage);
server.begin();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
client.publish("NOTHING/var1", "NOTHING/var1", 0, 1);
client.publish("NOTHING/var2", "NOTHING/var1", 0, 1);
client.publish("NOTHING/var3", "NOTHING/var1", 0, 1);
client.subscribe("NOTHING/var1", 0);
client.subscribe("NOTHING/var2", 0);
client.subscribe("NOTHING/var3", 0);
client.subscribe("NOTHING/c", 0);
server.handleClient();
if (Serial.available() > 0){
char c[] = {(char)Serial.read()};
mqtt.publish("NOTHING/c", String(c), 0, 1);
if (!client.connected()) {
reconnect();
client.loop();
long now = millis();
if (now - lastMsg > 2000) {
lastMsg = now;
++value;
snprintf (msg, 75, "hello world #%ld", value);
Serial.print("Publish message: ");
Serial.println(msg);
client.publish("outTopic", msg);
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
// Switch on the LED if an 1 was received as first character
if ((char)payload[0] == '1') {
digitalWrite(BUILTIN_LED, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is acive low on the ESP-01)
} else {
digitalWrite(BUILTIN_LED, HIGH); // Turn the LED off by making the voltage HIGH
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("ESP8266Client")) {
Serial.println("connected");
// Once connected, publish an announcement...
client.publish("outTopic", "hello world");
// ... and resubscribe
client.subscribe("inTopic");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
