Проблема с AT командами
clrn1w
При отправки команды "AT", выходит ошибка
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
    at processing.app.Serial.write(Serial.java:226)
    at processing.app.Serial.write(Serial.java:246)
    at processing.app.SerialMonitor.send(SerialMonitor.java:120)
    at processing.app.SerialMonitor.lambda$new$1(SerialMonitor.java:64)
    at javax.swing.JTextField.fireActionPerformed(JTextField.java:508)
    at javax.swing.JTextField.postActionEvent(JTextField.java:721)
    at javax.swing.JTextField$NotifyAction.actionPerformed(JTextField.java:836)
    at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1668)
    at javax.swing.JComponent.processKeyBinding(JComponent.java:2882)
    at javax.swing.JComponent.processKeyBindings(JComponent.java:2929)
    at javax.swing.JComponent.processKeyEvent(JComponent.java:2845)
    at java.awt.Component.processEvent(Component.java:6316)
    at java.awt.Container.processEvent(Container.java:2239)
    at java.awt.Component.dispatchEventImpl(Component.java:4889)
    at java.awt.Container.dispatchEventImpl(Container.java:2297)
    at java.awt.Component.dispatchEvent(Component.java:4711)
    at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1954)
    at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:835)
    at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:1103)
    at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:974)
    at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:800)
    at java.awt.Component.dispatchEventImpl(Component.java:4760)
    at java.awt.Window.dispatchEventImpl(Window.java:2746)
    at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
    at java.awt.EventQueue.access$500(EventQueue.java:97)
    at java.awt.EventQueue$3.run(EventQueue.java:709)
    at java.awt.EventQueue$3.run(EventQueue.java:703)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
    at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
    at java.awt.EventQueue$4.run(EventQueue.java:733)
    at java.awt.EventQueue$4.run(EventQueue.java:731)
    at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
    at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
vidok
Найдите ту строчку, на которую ругается исключение и посмотрите почему объект у которого вызывается метод или читается поле равен null.
