Hi! I had some developed firmware for 8710af series based on sdk3.5 from mp3 git repository.
I have some questions related with Sdram usage.
When I write the created binary to ram it seem to have strange behaviour:
It's ok to have SDR test fault when run from ram? (I will answer my own questions : sdram works but I don't know the source of this error)
How to get init correctly Sdram? How to correct configure sdk to work with rtl8195 and sdram? Select AM series in config files is enough?
Another question what is the correct jlink script to write in flash because the ones that I comes with sdk refuses to write on flash Even making changes for it run in linux
(I will answer my own question again) I managed to write on flash by slow down swd clock to 1Khz now flashburn comand write the file to the device but it still does not run But I think now it's another trouble since I had manually adapted the firmware (edited the header) and write the new image to 0xb000. I skip updating boot and call data and write a full flash with RTL00 flasher and it works! My version of RTL00 have a bug that it does not writes sdram img3 correctly only full flash works!
The jlink download script to SDRAM works fine with my image
By any chances any body have a jlink script to write a full flash? Because RTL00 is for windows and i had to keep swap computers every time just to write a file
Thanks!
<RTL8195A>
===== Enter SRAM-Boot 1 ====
CPU CLK: 83333333 Hz, SOC FUNC EN: 0x20111157
[SDR Err]Test 0: No match addr 0x44090 => 0x706abf06 != 0xa
[SDR Err]Test 0: No match addr 0x44090 => 0x706abf06 != 0x5515d575
Img Sign: RTKWin, Go @ 0x10006085
===== Enter Image: MP3 Stereo ====
CLK CPU 166666666 Hz
RAM heap 2175048 bytes
TCM heap 64768 bytes
RAM heap 2174256 bytes
TCM heap 57560 bytes
RAM heap 2153584 bytes
Thanks!
