extern "C" {
#include "user_interface.h";
#define BLYNK_PRINT_227476896_2 Serial
char auth_227476896_2[] = "D75TasbYkeegmH7CVXME66G1c06ceECQ";
unsigned long virt_203190254_1;
float input_OldValue_203190254_1= 0;
bool ESP8266ControllerWifiClient_HRD = 0;
bool ESP8266ControllerWifiClient_status = 1;
bool ESP8266ControllerWifiClient_isDHCP = 1;
bool ESP8266ControllerWifiClient_IsNeedReconect = 0;
bool ESP8266ControllerWifiClient_workStatus = 1;
char ESP8266ControllerWifiClient_SSID[40] = "Xiaomi";
char ESP8266ControllerWifiClient_password[40] = "84veros86wifi";
IPAddress ESP8266ControllerWifiClient_ip(0, 0, 0, 0);
IPAddress ESP8266ControllerWifiClient_dns (0, 0, 0, 1);
IPAddress ESP8266ControllerWifiClient_gateway (0, 0, 0, 1);
IPAddress ESP8266ControllerWifiClient_subnet (255, 255, 255, 0);
uint8_t ESP8266ControllerWifiClient_mac[6] = {0x0, 0x0, 0x0, 0x0, 0x0, 0x0};
bool _gtv1;
bool _gen1I = 0;
bool _gen1O = 0;
unsigned long _gen1P = 0UL;
bool _gen2I = 0;
bool _gen2O = 0;
unsigned long _gen2P = 0UL;
bool _count1I = 0;
unsigned long _count1_Value = 0UL;
WiFi.mode(WIFI_STA);
_esp8266WifiModuleClientReconnect();
pinMode(2, OUTPUT);
Blynk.begin(auth_227476896_2, ESP8266ControllerWifiClient_SSID, ESP8266ControllerWifiClient_password);
Blynk.connect();
int mytimeout = millis() / 1000;
while (Blynk.connect() == false) {
if((millis() / 1000) > mytimeout + 8){ // try for less than 9 seconds
break;
{if(ESP8266ControllerWifiClient_IsNeedReconect) {_esp8266WifiModuleClientReconnect(); ESP8266ControllerWifiClient_IsNeedReconect = 0; }
ESP8266ControllerWifiClient_status = WiFi.status() == WL_CONNECTED;
if (ESP8266ControllerWifiClient_status) { if ( ! ESP8266ControllerWifiClient_HRD) { ESP8266ControllerWifiClient_ip = WiFi.localIP();
ESP8266ControllerWifiClient_subnet = WiFi.subnetMask();
ESP8266ControllerWifiClient_gateway = WiFi.gatewayIP();
ESP8266ControllerWifiClient_dns = WiFi.dnsIP();
WiFi.macAddress(ESP8266ControllerWifiClient_mac);
ESP8266ControllerWifiClient_HRD = 1;
}} else {ESP8266ControllerWifiClient_HRD = 0;}
//Плата:1
_gtv1 = ESP8266ControllerWifiClient_status;
if (1) { if (! _gen2I) { _gen2I = 1; _gen2O = 1; _gen2P = millis(); } } else { _gen2I = 0 ; _gen2O= 0;}
if (_gen2I) { if ( _isTimer ( _gen2P , 500 )) { _gen2P = millis(); _gen2O = ! _gen2O;}}
digitalWrite(2, !(_gen2O));
//Плата:2
if (_gtv1 == 1) {
if(Blynk.connect() == true){
Blynk.run();
//Плата:3
if (_gtv1 == 1) {
if (1) { if (! _gen1I) { _gen1I = 1; _gen1O = 1; _gen1P = millis(); } } else { _gen1I = 0 ; _gen1O= 0;}
if (_gen1I) { if ( _isTimer ( _gen1P , 500 )) { _gen1P = millis(); _gen1O = ! _gen1O;}}
if (_gen1O){
if ( ! _count1I) {
_count1I = 1;
_count1_Value = _count1_Value + 1;
}} else {
_count1I = 0;}
virt_203190254_1 = _count1_Value;
Send_203190254_1();
bool _isTimer(unsigned long startTime, unsigned long period )
unsigned long currentTime;
currentTime = millis();
if (currentTime>= startTime) {return (currentTime>=(startTime + period));} else {return (currentTime >=(4294967295-startTime+period));}
void Send_203190254_1()
if(virt_203190254_1 != input_OldValue_203190254_1)
Blynk.virtualWrite(V0, virt_203190254_1);
input_OldValue_203190254_1 = virt_203190254_1;
int hexStrToInt(String instring)
byte len = instring.length();
if (len == 0) return 0;
int result = 0;
for (byte i = 0; i < 8; i++) // только первые 8 цыфар влезуть в uint32
char ch = instring[i];
if (ch == 0) break;
result <<= 4;
if (isdigit(ch))
result = result | (ch - '0');
else result = result | (ch - 'A' + 10);
return result;
void _esp8266WifiModuleClientReconnect()
if( _checkMacAddres(ESP8266ControllerWifiClient_mac)) { wifi_set_macaddr(0, const_cast<uint8*>(ESP8266ControllerWifiClient_mac));}
if( ESP8266ControllerWifiClient_isDHCP) { WiFi.config(0U, 0U, 0U, 0U, 0U); } else {
WiFi.config(ESP8266ControllerWifiClient_ip, ESP8266ControllerWifiClient_gateway, ESP8266ControllerWifiClient_subnet, ESP8266ControllerWifiClient_dns , ESP8266ControllerWifiClient_dns );
WiFi.begin(ESP8266ControllerWifiClient_SSID, ESP8266ControllerWifiClient_password);
bool _checkMacAddres(byte array[])
bool result = 0;
for (byte i = 0; i < 6; i++)
if (array[i] == 255) {
return 0;
if (array[i] > 0 ) {
result = 1;
return result;
