#include "ets_sys.h"
#include "gpio.h"
#include "user_interface.h"
#define SPI_FLASH_SIZE_MAP 4
#define SYSTEM_PARTITION_OTA_SIZE 0x6A000
#define SYSTEM_PARTITION_OTA_2_ADDR 0x81000
#define SYSTEM_PARTITION_RF_CAL_ADDR 0x3fb000
#define SYSTEM_PARTITION_PHY_DATA_ADDR 0x3fc000
#define SYSTEM_PARTITION_SYSTEM_PARAMETER_ADDR 0x3fd000
static const partition_item_t at_partition_table[] = {
{ SYSTEM_PARTITION_BOOTLOADER, 0x0, 0x1000},
{ SYSTEM_PARTITION_OTA_1, 0x1000, SYSTEM_PARTITION_OTA_SIZE},
{ SYSTEM_PARTITION_OTA_2, SYSTEM_PARTITION_OTA_2_ADDR, SYSTEM_PARTITION_OTA_SIZE},
{ SYSTEM_PARTITION_RF_CAL, SYSTEM_PARTITION_RF_CAL_ADDR, 0x1000},
{ SYSTEM_PARTITION_PHY_DATA, SYSTEM_PARTITION_PHY_DATA_ADDR, 0x1000},
{ SYSTEM_PARTITION_SYSTEM_PARAMETER, SYSTEM_PARTITION_SYSTEM_PARAMETER_ADDR, 0x3000},
void ICACHE_FLASH_ATTR user_pre_init(void)
if(!system_partition_table_regist(at_partition_table,
sizeof(at_partition_table) / sizeof(at_partition_table[0]),
SPI_FLASH_SIZE_MAP))
while(1);
#define GPIO_OUT_W1TS (*(volatile uint32_t *)0x60000304)
#define GPIO_OUT_W1TC (*(volatile uint32_t *)0x60000308)
static void gpio_intr_handler(int *dummy)
(void)dummy;
uint32_t gpio_status = GPIO_REG_READ(GPIO_STATUS_ADDRESS);
GPIO_REG_WRITE(GPIO_STATUS_W1TC_ADDRESS, gpio_status);
if (gpio_status & BIT(4))
GPIO_OUT_W1TS = (1 << 2);
if (gpio_status & BIT(5))
GPIO_OUT_W1TC = (1 << 2);
void ICACHE_FLASH_ATTR user_init(void)
gpio_init();
// Configure as GPIO
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO2_U, FUNC_GPIO2); // LED
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO4_U, FUNC_GPIO4); // Button
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO5_U, FUNC_GPIO5); // Wire
gpio_output_set(0, 0, (1 << 2), (1 << 4) | (1 << 5));
// Disable interrupts by GPIO
ETS_GPIO_INTR_DISABLE();
gpio_pin_intr_state_set(GPIO_ID_PIN(4), GPIO_PIN_INTR_NEGEDGE);
gpio_pin_intr_state_set(GPIO_ID_PIN(5), GPIO_PIN_INTR_NEGEDGE);
ETS_GPIO_INTR_ATTACH(gpio_intr_handler, NULL);
ETS_GPIO_INTR_ENABLE();
